Darkwood
No discrimination either. Unless one of the BS 1362's has been replaced by an M4 stud.
I recall Trev calls these "widow-makers." I'm inclinded to agree. Shocking.
Here is some things I've found over the years saw 100x more which is scary!
I started out to uncover the wiring behind plasterboard for a bank of four FCUs on the right connected to an RFC, that had to be removed. Then I discovered a separate circuit just above them, that disappears into the wall.
Puzzled by the two cables crossing under the two above circuits, I removed more plasterboard and uncovered a buried box to the left of the socket (this is a third circuit).
This was the (speaker/bell) cable supplying a small class 1 chandelier with 7 x G9 40W lamps in. Not got to the other end of the cable yet as going to have to lift boards upstairs, but expecting some melting. Customer said it stopped working a little while ago, and 230V no longer present. Cct isolated but customer also a bit miffed that I said to use only table lamps til I can get back!
Although not great it would probably work.
Assuming the door is hinged then the bolt looks like it would stop the door swinging open, the bolt is straight but the bracket through which it passes will not be moving in a straight line and would hit the bolt.
8K
Darkwood,
UKMeterman,
