Guest viewing is limited
O
Octopus
So do you stick them on CU? Are they necessary? Are they a waste of time and materials.
Cards on the table - I think we should boycott them completely!
I agree there is no need for them, however I usually fit them to maintain compliance. Never know which job may end up getting shown on your annual assessment.
Anyone who is altering a system that has mixed colours should have the knowledge and training to do so with competence. Knowledge of previous colour systems is part of being competent.
Not needed as if you dont know the colours you should not be in there but even as 7671 is not the law its still wise to comply.
unable to vote would have voted option 3 no need for labels
IF we stopped using lables, as much as they ARE annoying, would we not be contravening BS7671, our bible?
This is true but what purpose do most of them serve, I can see the need for voltage warning labels sometimes. My CU has an rcd notice but I can't remember the last time I pressed the button.
Hum.... so not fitting a label is really dangerous? I don't think so
The 18 ed should be amended to state the such a label is up to the discretion of the competent person....
i have a more useful label. ACHTUNG. GERFINGER POKIN VERBOTEN. NICHT PRODDEN MACHINEN
I can see the point of bonding labels, to try (in vain) in remind plumbers to leave them alone.
I can see the point of RCD test and frequency of inspection notices as they are aimed at the end user who may have limited technical knowledge.
I can see the point in dual supply/multiple isolation points labels for safety reasons.
Voltage labels are not required though in most LV situations.
Does anyone pay attention to rcd notices, yes the dual supply notice I agree. Voltage warning labels yes, but I agree only in limited instances on LV systems.
I don't get any of them. People who have no knowledge of electricity or related systems don't take a blind bit of notice of them, and people who work on the systems should know what they are doing without having labels to remind them. Waste of time and effort. Good way of demonstrating to an assessor that you have read the reg's though, even if the rest of the install is sh1te. Last time I got assessed he just tapped each of the labels on the CU, nodded and that was that, after a quick Zs test.
Well as anything goes for DIYers then we have to assume they may work on their own home system.
And they could be coloured blind so not notice the old pre harmonised colur difference. So I'd say yes. May as well stick it on just in case tgat highly unlikely occurrence should happen .
But what if they are blind? Should we be fitting braille notices as well?
For the minimal cost and time involved we might as well cover ourselves, yes we know these labels are of little relevance as customers generally take no notice, BUT the need for them is a requirement of BS7671, so in the event of something going wrong if the blame could be directed towards lack of information he implications could
Fitted a ten way board a while back, only had three circuits but had to fit a big board cos labels wouldn't all fit on a small one:)
Couldn't you have put them on opposite sides of the door? I had a customer moan like crazy the other week about "all those unsightly stickers" so I put them on the inside of the door", is this allowed?
I think if a person with no knowledge of wiring colour schemes created a dangerous situation worthy of apportioning blame, the onus would be on the lack of compliance with BS7671 regarding the bodge and bodger, rather than the lack of a sticker.
Ok but what if [for example] an RCD failed to operate in time during a fault and someone got a nasty shock or worse, if there was no quarterly test button label that could go much further....
Well I have said I agree with those labels and their use. The label up for debate here is the mixed colours one.
What about this;
___________________________
............WARNING.............
..NO WARNING LABELS FITTED..
Perfect but should it refer to the "labels" section in BS 7671?
This approach is certainly going to get the backing of the green brigade - all those labels being made, transported .......
On one assessment, I got a ticking off for not putting a "230V" warning label on a Wiska Box feeding some SWA. So I said to the guy, shouldn't I be putting them on all the sockets/FCU's/inspection boxes/light switches and any other bit of kit that some numpty might decide to remove the cover from and stick his mitts in then? He just smiled....
Well, not for the mixed colours label it doesn't actually, but the regs for the RCD label and inspection date label state "in characters not smaller than those illustrated" then specify the wording.
514.12.1 and 514.12.2
In which case i won't fit them any more.....
Dual colour warning labels
Octopus,
Jacek Buczak,
