first dead test the element. continuity and IR. if all OK, then power up with a clamp meter in use. see if it's drawing juice. if it is, sounds like the sensor or the stat has failed.
So the options are:
Fuse has failed
Mat has failed
Sensor has failed.
You can do the first one but without test kit the 2nd and 3rd you can't do anything to test.
sussex
Underfloor heating not working
MJC,
Squid,
