Discuss Live to earth 25ac live to neutral 230 could anyone help in the UK Electrical Forum area at ElectriciansForums.net
where are you testing switch or light !I am currently redoing a kitchen, (electrics) I tested voltage at lighting cable and form brown>blue-230ac
Brown>earth I got 25ac could anyone shed some light on this please
you should have some one looking over your shoulder when you are testing a give guidance.I am an apprentice I am testing with a fluke t5-600
is any body paying you for this work ?I am currently redoing a kitchen, (electrics) I tested voltage at lighting cable and form brown>blue-230ac
does your mum and dad know what you are doing ,like going to burn your house down &no p/l insurance .No, it is in my own home
is it not time you should be in bed reading a comic .I was only asking on this to see if I could get some help, if it was out of my knowledge I’d tell them I couldn’t do it I wouldn’t complete it not knowing what to do, that’s why I asked on this forum for hlep
Come on buzz, the lad's a bit puzzled......it'll do him no good going to bed with a copy of the 18th edition....is it not time you should be in bed reading a comic .
True, and is the light switched on or off...is it a permanent live or switched? A few unknowns. Is there only one cable at the fitting? If so, odds are there's a nearby joint, of some kind.Another option, is that the polarity is reversed.
Test a socket, see what readings you get.
….is their a bunch of cables above the ceiling?...may be something amiss there. If it's a switch wire, that's the first thing to look at.Try and test near the consumer on the lighting circuit and see what voltage between the line and cpc
Reply to Live to earth 25ac live to neutral 230 could anyone help in the UK Electrical Forum area at ElectriciansForums.net
