Discuss Whats your thoughts on this in the UK Electrical Forum area at ElectriciansForums.net
Think you'll find that most developers want the painters & decorators into the building as the last working trade. Stops the grubby hand marks & screwdriver marks from an uncaring electrical bod etc.
The details are in the contract as everything is at a price the sparks screwed the faceplates to the backbox its not the painters job to remove and bag them up and the sparks went do it as they won't be paid, its shocking at the bodges that these new builds have and I really do feel sorry for the buyers as they will be fobbed off by the developers and fIIcked over.
I have you know, don't you know, some business prefer the method of caulking & painting after the fitment of faceplates.
It is completely normal for new-builds to be rushed as the completion date approaches...the builders are under pressure from the banks...if you study the sales contracts/missives you can easily see how biased the deal is towards the builder...this is not an excuse for crap work, just a reason. Builders charge what is an exorbitant price for what are often pretty crap houses, and there has to be some sympathy for those who work for them because if they don't quote low they don't get the job. That's a sad but unavoidable situation. It would be great to take the view that you will only do the very best job...but if you have no work, you have no income.
However, if you are skilled, you are probably fast too...but if you are that skilled, you shouldn't have to compromise on quality or price...it's just another example of the money-men ruling the roost.
Pre-financial crisis times, so many people bought plots and had kit houses erected, thus having control over the work-flow and quality, whether they did it themselves or had trusted tradesmen on hand to do the work to a good standard. Sadly, post 2008, the banks (again) effectively stopped lending for self-builds. That meant that those who could, with maybe 3 self-builds, get themselves a quality home mortgage free, were no longer able to do so, and, with the pressure on finding a home, fell prey to the poor quality mass-produced housing market...and that trend does not look like ending soon.
What is increasingly worrying is that corners are being cut not just on inessential areas like painting and plastering, but on major areas of safety like electrical installations. I have seen so many examples of dreadful workmanship ( I am not an electrician, as you know, but glaringly obvious practices abound) that it leads me to believe that if an amateur like me can see these problems, they must be very poor indeed. Shiny kitchens and bathrooms sell houses...shoddy electrics can kill.
The powers that be listen to the builders' lobby, not to the consumer...thus we have an erosion of standards...toilets off kitchens without an intervening air space, CUs in cloakrooms mounted high up above the WC, and an insistence on disabled access to every house which often leads to a ludicrous entrance when that type of access should be provided by the builder as and when required, and by the local authority when a second or subsequent owner shows reasonable need...but the local authorities are only interested in garnering more council tax and sell the planning permission for so-called plannng gain which is usually so badly managed that the benefit to the public is next to worthless.
So, as my rant reaches an end (or a pause!) we have banks/LAs/builders all forming a barrier to good workmanship, thus conspiring to produce poor quality homes at inflated prices.
I won't list any more grievances at this time, but just suggest that if the LAs insisted that the mainstream mass house builders had to meet the same quality that they insist retirement home builders like McCarthy and Stone achieve, there might finally be a market for all you quality electricians out there. (They're not faultless either, before you protest!)
Oh, and the screw-slots should be horizontal!
I would not accept that, if the plasterer is top notch and the fitting fit to purpose then it all should fit flush using caulk is just for filling in the cracks after substandard work has been completed, painting should be done before plates are fitted.
If you accept this standard of work then God knows where you lot work or who for as it is truly an eyeopener at what you accept as the norm, maybe in the past I have worked at higher end jobs or just take pride in my work.
You are just looking for trouble tonight, hang on of to the off licence to get some beers and order an Indian,
Everyone has choices if you are told to cut corners then you are as guilty as everyone else, I have looked enough people in the eye and told them to stick it when it was "suggested" that I screw the system, it just looks like a lot of people have lost their moral compass and I tell you one thing karma is a bitch when it returns to bite you in the arse.
Part of the problem is that the prices & time scales to do these houses is so tight that every opportunity to cut corners is taken
Inserting the CPC into a terminal block rather than the box terminal doesn't save any time. What it tells me that whoever is doing the install is not competent We all know why we earth the box with the CPC they don't they seen to be oblivious to what they are doing just putting the cables in the terminals they have been told to but don't know why. As for the chalking in of the switch, this makes it difficult
to inspect and non-assessable without damage to the decoration. The screw caps are just for ascetics.
midwest would you agree to do a substandard job because of cost restraints or some arsehole told you to do it to earn a few extra £'s, or would you allow work like that to be carried out at your house? I have never ever heard of caulk being use around faceplates to "tidy" them up.
Some people really must have low standards of workmanship and the acceptance of bodges no wonder the trade is going downhill.
Reply to Whats your thoughts on this in the UK Electrical Forum area at ElectriciansForums.net
