Discuss Domestic - What do you normally use? in the UK Electrical Forum area at ElectriciansForums.net
got up for a pee. then coffee while dog's let out for pee also.
What are the advantages to the installer of using conduit over capping? Surely chases have to be deeper and isn't it a faff feeding t&e down it?
If fresh block work is being hardwalled and skimmed do you have to chase oval conduit in a bit?
Always just used plastic capping because that's what those I have worked with use.
Conduit makes the job more professional & also, it’s easier to re-route cables when the architect suddenly decides it’s Monday morning and he’s going to change the drawings for the 100th time.
Not sure I agree that conduit is "more professional" though.
Reply to Domestic - What do you normally use? in the UK Electrical Forum area at ElectriciansForums.net
