Guest viewing limit reached
I'm currently in the process of running neutral wires around my house to all the light switches so that i can install some of these new wifi smart switches to control all of my lighting.
One of my light switches has a black and a blue wire connected together separately from the switch shown in the attached photo.
How can i tell for sure if they are neutrals?
Dug out an old multimeter with longer wires to test the continuity between the switch and the light. Turns out they are neutral.
Win for me as i don't have to run a neutral to this switch now!
I'm curious on how you are going to run Neutrals everywhere.
(without ripping your house apart! :))
All the switches are on stud walls. Downstairs are close to the landing which I'm waiting to carpet and then upstairs I'm going to try running them down from the loft. Will be interesting to see if it is possible or not.
What type of wiring are you using for these new neutrals.
They will require suitable enclosure/protection if they are not pvc/pvc insulated.
Yes but not 16.0, you can get 1.5 though but can be hard to source.
Im confused, you had zero volts from the perm live at your switch to your suspected neutrals at the switch, but continuity from the suspected neutrals at the switch to neutrals at your light? or were you testing from an unenergised switched live? hence no voltage at the switch!!!
I was given a couple of rolls of sheathed & insulated single red & black and of sheathed & insulated single & earth a few years ago, virtually unused. They prove very handy from time to time - with the appropriate sleeving at the terminations, naturally...
And the first time I came across twin brown I asked a customer to pop to Poofix on a weekend to get 100m 1.5 T&E and they returned with 2x 50m reels “as it worked out a lot cheaper” - because it was twin brown! That made the feed on the lighting circuit interesting....
The last train brown I collected (yesterday) the wholesalers said "there's your 2.5 masquerading as a bit of twin brown" :-)
For those unaware Irish Standard 201 cable has a full-sized and insulated cpc which gives the cable the appearance of the next cable size up for British Standard cable. (I stock both Irish Standard and British Standard cable.
probablt because the BS is cheaper?
I ran neutrals to my upstairs switches from the loft. Pulling 3C+E with T+E worked perfectly for all but one which it turns out ran through a couple of really tight holes drilled through the stud frame.
Some choice words were uttered when the tape snapped, but on the bright side I'm now a lot better at using my access rods than I was before!
Rayleigh
Are these wires neutral?
Stevieg2,
Risteard,
