Andy78
Mentor
I really need some help in a project I have become involved in wiring a lived on boat. It's something I have not done before or anything remotely similar so I'm well out of my comfort and confidence zone.
I'm really struggling finding a definite guide as to the correct regulations I need to be following or even any best practice guides. If anyone can offer any experienced advice in this field I would be most grateful, even a finger pointing in the right direction would be great.
I'll refrain from posting detailed info about the job until an experienced mind pops along as it might be a bit much.
The installation on the boat is nothing special- just to bs7671
As long as it’s connected to a supply conforming to section 709, marinas and similar locations.
Section 709 shows the supply cable on the boat, and special regards to metal parts in contact with water.
I think you have to carefull that you dont connect the metal hull to earth as it can course corosion i think , sorry to be vage on it but i remember it being talked about back when i was in college , worth looking into.
Ok, bit more info.
Won't be connected to a shore hook up, but will have the capability to be.
Boat is a steel hull
Will be powered via solar panels charging 12V batteries.
12V and/or 230V (via inverter) will be used for lighting and power with a 24V system for the engine room solely for the engine start operation.
If its a canal barge, you take it on the right hand side, and not the left when "driving" it along.
I took a family members boat along the Union Canal in Edinburgh from the centre out to the bypass. There's an aquaduct crosses the 4 lanes of the bypass... my kids on the bow waving at the drivers below.
Only thing we had to watch out for was the university canoe club.
The Union Canal needs a good dredging. One time I wasn't there, the boat picked up an old mattress from the bottom and wrecked the propellers. A week later another boat brought up a corpse. :eek:
If a steel hull there are some caveats, however as the majority of the installation is 12V or 24v then you are simply providing shore power, perhaps from a marina supply?
If you are only providing a supply for charging the battery bank, the job is easy. If you are providing a mains supply for heaters/microwave/lighting, then you have a double-double insulation task, especially in a metal hull.
Don't be miss-led by the anodes bolted to the hull to protect against corrosion. You need to keep the shore power completely isolated, as if you were running a heater off an extension lead.
It's an interesting problem, but not needing over-thinking. Hardly anyone dies linking a boat to the marina supply with a commando plug...like a caravan, but with a bit of a twist?
just treat it like a mobile home .
The idea is to generate all power to charge the 12V batteries from solar panels. No available shore hook up at the mooring location. Inverter will be present to provide 230V for a fridge and telly, possibly games console too for the kids.
I think I am over thinking it a bit maybe but was already thinking along the lines of a double insulated system.
nice gun boat Andy ,are you making sh77 shape for going to pick up some passengers across the pond near Calais France.
That's a proper boat, Andy!
Yeah 'tis a proper boat isn't it ? Will be my brother's new home when finished. So much to do on it but will be great when finished.
We are currently busy ripping out the "renovation" done 15 years ago. What a bodge. Taped connections on all circuits, polystyrene used as insulation holding moisture against the steel hull, flammable materials used in the bedroom ceilings. It's a start again job.... for everything.
I will try a dig guy martins number out for you to give some tips .
Good shout there, but it's a boat, not a ship...wire it in 4mm singles for the 12v side and all will be well
(apart from the windlass and starter motors, obviously)
I'll not be touching the engine room wires or any of the 12V gubbins that runs up to the wheelhouse. That job can be for the professional tinkerers. It just about limped to it's current residence with the gear actuators blowing a boxful of relays in the process. It won't need to move for a year now so that's not a priority really.
It's a mess in the engine room. Two huge double decker bus engines live in there hibernating in a nest of diesel and oil. Water has stopped coming in though which is nice
My brother did make me laugh with his story about his leaky stern glands.
I would recommend hooking up a sacrificial (galvanic) annode to the hull if its steel and submerged, it prevents the hull from rusting. Its like the same principle as derusting stuff with electrolysis. Alot of boats in the water with electric running through can make the water more corrosive. Think of the boat without a galvanic annode like, i dunno, a car with a badly rusted whhel arch, !
if they are the LXB as on a bus, they're a belting engine.i had 1 on a double decker bus converted to live in. started 1st time after standing 2 years. don't forget. on a boat you run them on red diesel. less than half the price. in summer they will run on chip oil,
and you still have to pay tax on red diesel...you only get a tax break if the fuel is for heating/cooking, typically 10 or 20 percent, if you are lucky...unless it is a commercial vessel.
BS EN 10133 is what you need for the 12V (or 24V) DC side of things, and BS EN 13297 for the 230V bits. I'll try to summarise the main bits of the former.
Blue Sea Systems do good quality panels and switchgear (at least, their DC stuff is good, don't know about their AC stuff). I upgraded the wiring on the last boat I owned.
I lived on narrowboats (prior to getting the Zeeschouw) for about 10 years.
Some random bits from BS EN 10133 (that's different from BS7671):
- hull can be grounded (usually is, at the engine) but obviously you can't use the hull as a conductor. Only grounding the negative conductor in this way is permitted.
- 10% voltage drop permitted, however, some circuits will "typically require" 3% or less: panel boards, nav lights, bilge blowers, bilge pumps, other equipment where specified by manufacturer
- batteries shouldn't be able to move more than 10mm (horizontally or vertically). You need to supply leaking electrolyte containment for tilts up to 45 deg.
- need a battery-disconnector switch on positive conductor, easily reachable, as close as practicable to the batteries (exceptions for things like solar panels, bilge pumps etc as long as they have a protective device close to the battery).
- flexible or stranded insulated conductors, fire-retardant material, e.g. not supporting combustion in absence of flames
- conductors in engine room at least 70C and rated oil resistant, or protected by insulating conduit or sleeving
- minimum support distance 450mm, or 300mm on cable to battery switch.
- minimum size for singles = 1mm, for multi-core flex 0.75mm (except for panel boards, where 0.75mm singles can be used)
- not in same containment as AC wiring. If not separated by partition etc, then minimum distance in free space = 100mm
- DC negative conductors should be black, or yellow (unless you're using black in AC, in which case, use yellow). Black or yellow must not be used for DC positive. Avoid use of brown, white or light blue in DC system, if AC is present on boat.
- terminate appropriately, e.g. "no bare wires to stud or screw connections"
- socket outlets should not be interchangeable AC and DC
The usual restrictions about IP ratings etc apply.
In practice, invest in lots of flexible PVC conduit. Run your DC singles through it (generally red and black), and (generally) AC flex through it (separate ones, obviously) too, for getting it around the boat.
Hope that's helpful :)
Andy78
Mentor
Kingston upon Hull
electrical installation on a floating dwelling
Andy78,
pirate,
