John R
Hi
I’m new to the forum & just a DIY’er!
I’m running a 15m length of 2.5mm 3 core (twin & earth) SWA to our decking at the back of the garden for a double socket.
Must the steel wire armour be earthed using the banjo or is the CPC core sufficient?
Thanks in advance!
J
Alright, that’s four of you that said it must be earthed. Thought someone might have added something else to the discussion.
i can add loads to the discussion.....
1. why do you ask when it's clear in BS7671?
2. is it being installed by a competent sparks?
3. where's my beer? (this Q for missus, as she's only doing washing, ironing, washing up, dusting, cleaning, women say they can multi-task, so why my beer not within reach?
I'll add a bit more.
SWA cable is not "twin and earth". SWA cable is 2,3,4 core etc. All cores are separately insulated. You may choose to use one of the cores for earth. Or you could use the steel armour (subject to a number of tests, calculations and checks) as the earth.
The flat stuff that is used for fixed wiring inside a house , like this
is twin and earth.
Thanks for the decent answers. I made it perfectly clear that I am a DIY’er. I realise that there are a BC & wiring regulations but I cannot justify the £££ needed to purchase them.
I also realise that I need RCD protection and that the cable needs to be buried 500mm down with the plastic warning tape less deep.
I know what traditional ‘twin & earth’ is...what is this then?
SWA Single Phase Armoured Cable - https://www.toolstation.com/swa-single-phase-armoured-cable/p57367#full-desc
If everything is clear in the regs then why have a forum for advice?
Welcome to the forum mate.
I presume you know this work is notifiable, under Part P?
I take it that you will be notifying them. I've been told that this will cost a bit.
Because BS7671 "The Regs" are a right PITA for electricians to understand, let alone Joe Public, sometimes the voice of reason is better understood.
My stepson is a sparky & checks all the stuff I do & signs it off. He’s coming over next week to show me how to change the consumer unit!! :grinning:
For him to be able to legally sign anything off, he has to be there at specific points in the jobs progress, he also has to be registered under a Third Party Certification scheme, is he?
Who'll be doing the required testing before and after the job and who'll be completing the Electrical Installation Certificates and Part P to LABC notifications?
It's worrying when we hear an amateur attempting a job that can potentially cause death or injury, if not now, but in the future; who doesn't know what they're doing. (Your original question proves that).
Professional, legitimate electricians have had to invest £1,000's in training, test gear, scheme memberships and continual updating of their knowledge and resources. We're professionals for a reason, we know what we're doing, amateurs don't, and with electricity that's a dangerous situation.
"any idiot can get a circuit to work, but it takes knowledge to get it to work safely"
Harsh but fair
You don't need rcd protection for the SWA cable .Have you check with your stepson that you have the correct size of cable for what you are supplying ?
I'm sure the OP's stepson will tell him everything he needs to do.
Not sure why he's here, if his stepson will be signing off everything.
Maybe he's on holiday....
Then fit an rcd socket , the swa cable does not require rcd protection.
Seems like you're being hard headed, is your football team losing?
Every cable requires protection!
I'd stick the rcd in a dB for many reasons. If you want I could explain them.
Nothing wrong in @Flanders post. It's to the regs. :)
Most rcd socket can't be Ir tested. It's suboptimal at best. Outdoor socket no ability to Ir test = trouble brewing.
What I said about every cable requiring protection is true. He said the cable did not require rcd - very misleading
I misread or he edited his comment. I thought it said cable did not require protection. Not rcd protection
The cable is for a socket is it not?
Yes there are good reasons for both and im not saying you are wrong . Some cases it may be cheaper to fit an rcd socket than fit rcbo , or there no room in the board to fit an rcd , the list go on , or it could be easier and cheaper to fit an rcbo in the board .I was just pointing out that a SWA cable does not require rcd protection , O and I don't follow the football ☺
I've posted why rcd socket is a bad idea. Feel free to disagree.
I apologise for being harsh on you. I'll make an effort to to be nicer
That what I'm saying i don't disagree you can put the rcd where you like ☺ Just read my post properly in the future ☺ps i did not edit it .
John R
West Yorkshire
SWA - earthing the steel wire?
John R,
John R,
