Here is a little peach I found today whilst attending a faulty immersion heater, work was done only 2 years ago by a big national company fitting new heaters! Nothing seemed to be fixed back properly and the lid fell off the isolator as I took the clothes out that were hiding it! :(
@Dustydazzler
Yes that is correct then they have been neccy blocked to the original cables to the heaters in the old wylex unit below, lovely job!
Reactions: SparkySy
Yes the other cable has been pulled back up in the trunking, why the other 2 couldn't have done the same as they all came down in it!
It was one of those jobs you wish you could unsee!!
Reactions: freddo and DPG
Been asked to sort this lot out at a well known uni. Data engineer got a shock pulling new cables in. All singles just in trunking. No lid.
Reactions: freddo
@ChrisElectrical88
The main tails used to come into the lower right hand old wylex, they have been pulled out and put in Henleys then to the new main switch, then out to more henley blocks and then to their respective final con units!:eek:
you want an EICR on this?????
Some workmen outside my apartment in downtown Baku, Azerbaijan - just inside the door I found their power tool was connected like this...
Whats wrong with that? Once we’ve left the EU all this health and safety rubbish will be out the window and we can go back to all that make do and mend stuff. The British empire was built on innovative solutions like that. What do you think a Royal Engineer would do if he didn’t have a 13amp plug for the laser guided missile he was installing ... and sod part P? ;)
It's why I do my own electrical work...they'd wire up the whole house like this, given the opportunity!:eek:
Reactions: Wilko and DPG
I installed the mains supply and isolator for a future fire alarm system. We recently went back to the location to see the fire alarm system had been fitted. Thank god the system was wireless. Don't know why I bothered measuring the fixings, neatly dressing the cable and making sure all the slots in the brass screws were at the same angle.
Seems they needed a repeater, cables lashed into the nearest socket circuit.
Geez... It’s really not hard is it? Some people give me the shits. Can’t take the time to adequately measure a few Double P clips.
Reactions: freddo
Radial circuit making beeping noises. It didn't do it again after it stopped...
Reactions: SparkySy
3ph service head in clients "storage cupboard" a few months ago... Yup 415 between those exposed conductors.
Its UKPN here so hopefully by the year 2055 they'll send someone out with a tube of superglue to "fix" it, in the meantime I've asked him to maybe not clout the cupboard contents of his metal handled mop, clothes airer etc etc etc into it
Here is a blast from the past!
[automerge]1570740717[/automerge]
A bit of light reading?
Found today and disconnected it! Book case will have a new 4mm back put in to hide the hole.
Creative wiring, the switch was on the landing, the trailing socket in the roofspace above feeding a CO alarm.
I don't think I've posted these before...
In a lovely old pump room [may share photos in another post if anyones interested as it's generally in excellent condition]. Lighting still wired in VIR singles. More recently someone has spliced in with harmonised singles to supply a row of T5 flourescents in an adjacent building...see the crushed and sweaty looking VIR neutrals below.
Reactions: freddo
Saw a load of old conduit wiring and thought oh no rubber. It turned out to be fabric covered plastic insulation. The telephone cables hacked into the box and the earth tapped off of the lid screw were less positive. Insulation and earth loop readings were excellent throughout the installation.
Bet you'd get a prize from Tupperware for sending in the picture :)
Guess this went to the lowest priced tender
When you have to call a gas engineer to an electrical fault???
Do you reckon someone's done that as a DIY meter move? Can see the gas board doing that.
Reactions: freddo
Nope.
When I left today at about 3 o'clock, I told the householder to call British Gas and report it. It was changed a couple of years ago.
Got a call at 5.00.....they were on site changing it. What a response!
Only problem now is a L-E short on the shower circuit. That lot's low down in a kitchen corner unit :rolleyes:
Another bit of a job helping someone out.
Just a observation whilst onsite.
Amusement, I'm shocked, what on earth is going on here, whoever did that want's His / Her tools confiscated and sent back to school for further instruction , awful really awful work. love to see the installation pr EICR cert covering that abomination, going to the bathroom for some anti nausea medication.
Pete, your post has been edited as we are stamping out the pointing of fingers towards people that take the short course route into the industry.
OK point taken
Reactions: DPG and Sintra
found today. new water meter installed. incomimg water is plastic. then copper from stop cock to meter. then plastic from meter to copper in house. united utilities installed bond from copper before meter to plastic after. fair to the guy who told customer it was pointless, but his boss says that's whathe has to do. .the mind boggles
Customer:
“So, mr telectrix.... you were in the cupboard last taking a photo of the water meter. What happened to my 4 bottles of wine?”
Tel:
“What wine?....what cupboard?..... wasn’t me, m’lud”
Reactions: richy3333
Shocking really the levels of incompetence, he hasn't fitted the do not remove labels to the clamps.
I should go careful there tel.
that looks like a witches broom in the corner, don't want to upset her and get turned into a frog!
So does that mean a C3 in an EICR for no "Provision of earthing / bonding labels at all appropriate locations (514.13.1)"?
8K
Darkwood,
mainline,
