nah. from Knotty Ash. where the jam butty mines are. just down the road from where i was born.
  • Funny
Reactions: JK-Electrical
Ummmmmmmmm, Seems legit.......??
Maintenance free connectors, strain relief clamps, sleeving????
  • Optimistic
Reactions: ferg
Doesn't need to be maintenance free as you can clearly get access to it;)
What’s under the paper bag.....?
Old single socket and metal back box......easily accessible after removing carpet...hardboard sheets.....paper sheets and then using 2 crow bats and a hammer ?....did me a favour though really as I was extending the rfc, took one side straight up into my new socket and then ran a new leg to my next sockets..
I remember going to Knotty Ash stadium when Huyton played rugby there......locals from a council estate wrecked the away team coach.
This is all going at a fare wraite of nots....
Don't need to worry about minimum bending radius when installing SWA.
We all know how important proper cable restraint is...
talk about being between a rock and a hard place.
This is where it goes next...
along the sand and into the stream...
customer kindly put the armoured cable in ducting. It buries itself ?
Nice...
Self-burying conduit!
Both @Pete999 SWA inside the duct. The ground is basically made up of rock so won't be easy to bury and will never get to the required depth. Glad its not my job on this one but customer is very skilled (just built his own house) and will get it in the ground.
Reactions: ruston
Another nice tidy fire alarm installation.
Been banging on about the need to change all the floros with LEDs for a while this might speed it along a bit. DSC_0274.JPG
Reactions: freddo
  • Funny
Reactions: Midwest
Got called out because a light wasn't working...
Reactions: Fazz711 and ipf
There was a hole melted into the diffuser too that no one had noticed. :rolleyes:
Reactions: Wilko
Says it all :rolleyes:…...at least you're not piddling about with a new lamp holder :)
Yep, nice new twin led anti corrosive now in its place.
Reactions: Fazz711
could you not have soldered the wires on to the tube pins? :p :p :p
Reactions: ipf
Looks like that might not have been needed...no MIG welder either. ;) :)
Two industrial units. Namely Unit 1 and Unit 2... Used to be all one site with one electric supply, but now split.
Unit 1 has had a sub meter put in to measure the electric Unit 2 uses until they get a dedicated supply put in by Scottish Power.
I think the installer got a little mixed up....
8K
Darkwood,
mainline,
