Darkwood
It amazes me what will still work, this install is probably 40 years old and apart from a newish consumer unit has not been touched. Still has the old coughtree swan neck outside lights and all sockets were the old mk type, mainly singles.
Snipped back the corroded wire and the tarnish didn't go much further that where it was exposed to air and damp. Surprisingly the insulation test came out ok as well! Re-terminated in a lovely wago box and put back into service!
[automerge]1595878232[/automerge]
Another quality job
Caravan supplies no less!
I think it was very lucky for all the spike that is holding this aloft never touched anything live
inside as the RCD did sweet fa! :eek: :eek:
Soon made that a bit safer!
Before anyone comments, yes I did label it all with my trusty dymo!!
It’s bad enough that this sfcu is grouted into the tiles, until you see where it is.
another pic taken a step back...
Another step back and I’d be in the shower.
Luckily this point had been disconnected, and another placed through the wall outside the door. At one time this switched the towel rail heater.
(laughed when sfcu was autocorrected to “sexy”)
Yes, I've often wondered about buried stuff like that. There's so much of it about, I can only assume most of it is better sealed than that was - gland not fitted properly or wrong type ?
No idea, I merely showed them it, dried it out a bit and put it back!
I assume they didn't put a gasket/seal between the gland and box.
8K
Darkwood,
vjsmarwick,
