Darkwood
Just in cast you guys don't know it's a super size moon tonight, have a look it really is bigger than normal due to its elliptical orbit it is about 50,000Km closer than normal in real terms about 7% bigger.
Are you in to astronomy, or just a casual thing?
I really want to move to astrophotography, but overall it is just too expensive to do it properly, so I just observe with a 130mm newton in the garden.
I had a 500mm lens with a 3x converter when I was a lot younger . I used to love to scan the moon . It stemmed back from my upbringing on a farm, especially in the winter nights in the days of the heavy snow searching for missing livestock.
Went back to the place with the dodgy conduit alterations. Wish I could have taken some more photos of the newly installed electrics. They keep mentioning 'their electrician' but its bloody obvious they are DIYing everything. I did manage though to get a photo of their DIY attempt at installing a fire alarm system that they put in last week:
While we were there found more stuff while correcting the conduit bits I posted a few weeks back. The singles were joined in behind the plasterboard and totally crushed between the woodwork and the wall at the top and couldn't be pulled out:
We did sort the conduit though:
I still have my Tamron 500mm mirror lens I bought in about 1987 - managed to get it adapted to my Olympus digital last year and it worked quite well on the moon. I lack the patience to set it up properly though.
I would set up a time lapse, but the cat would likely have it over before I left the room!
Yes it takes a lot of time , but it is worth it.
I was using Minolta SRT 303 at the time. (memory might be faded) . You need a fast shutter speed or the Moon is a rugby ball lol.
My mirror lens was just a cheap one , If Tamron made converters , it was a Tamron as I had a few Tamron lenses, but most of them were Rokker.
For a cheapish mirror lens the prints were good. I did them in black and white and developed and printed them myself.
One of my many hobbies, I have a 250mm maksutov-cassegrain on a motorised polar mount set up in an observatory, I say observatory, but its really the workshop with a lift off lid pointing South, the prism mount eyepiece allows my Minolta to be used for Astro, quite satisfying, but pictures of star clusters leave me a bit cold, have some good photo's of the planets, the moon below taken 8th March 2007, if I remember correctly its 250 images taken over three hours, black and white on 1st Jan 2007 as a set up.
Ah,
It's actually DSO's that I am more interested in, my screens background image is m51, I bought some time on a telescope took several images, stacked and blended R,G,B,Halpha, OIII, AND SII (plus all the darks etc) and got a half decent result.
It's soo expensive though, I ended up throwing away around 40% of the images as satellites etc passed during the exposures.
I would love a decent refractor plus dedicated camera and filter set up on a GEM, but haven't really anywhere to set it up, so both not practical and too expensive for me
It's actually DSO's that I am more interested in, my screens background image is m51, I bought some time on a telescope took several images, stacked and blended R,G,B,Halpha, OIII, AND SII (plus all the darks etc.
I know it don't ake much to confuse me but that does it in Spades. confused.com. ??
DSO = deep sky objects, usually other galaxies
M51 = The catalogue number of a DSO in this case the whirlpool galaxy 1yd5cl5d9lo21.jpg
To create this sort of image you take loads of photos with a b&w camera with filters for the colours
R, G, B = Red, Green, Blue filters
Halpha = a narrow band filter based on the alpha line emissions of Hydrogen.
OIII = narrow band of Oxygen
S2 or SII = narrow band of Sulphur
These images are all blended together using colours, and so on to give an image.
The last bit is a type of telescope, camera, and mount
bloody expensive hobby. to do all that I'd be getting through at least 6 cases of beer.
Yup, that's the problem!
Last year I decided to buy time again, this time I did m27 (dumbbell nebula)
(Not my image)
But made a complete b***s of it and used time with the wrong telescope - ended up with a field of view too large, and such a tiny image that it was all completely worthless!
Around 8 hours ($140) thrown away.
Took my ball in and sulking since then!
Brilliant images Julie the M51 is one of the best I'v seen, I have no doubt you know but for others the Space station goes across tonight: Time: Tue Mar 30 10:14 PM, Visible: 4 min, Max Height: 79°, Appears: 10° above WNW, Disappears: 79° above ENE
maybe they were put so far away so that the Catholic Church could believe that the earth was the centre of the universe, then along came copper knickers with his telescope and almost got himself burnt at the stake for heresy.
my van must be...... a crisis many light years away , I'll be long dead before it gets here.
Basics is an interesting marketing choice for a life saving piece of equipment. Do you get nectar points with them?
This is clearly someone who is tired of waiting around for the manufacturers to develop the nirvana of standard switchgear that you can mix and match.
Not sure about the type testing, but looks like it's actually coping quite well with the loads on an engineering level... almost impressive to take the time to do that rather than pop to Screwfix and pick up their cheapest board.
seen worse cobble ups.
BS 1363 introduced 1947. round pin sockets and plugs phased out late 50's maybe early 60's for some. usually replaced on rewiring VIR cabling or to match the new fangled plugs available. at the time it was not usual for appliances to come with fitted plugs, so you fitted whatever suited your installation, or just stuffed the wires in the round holes with whatever suitable packing was available.
8K
Darkwood,
mainline,
