Darkwood
Installed many of those Bentall (?) roller mills over the years. Learnt that to increase reliability, it was a good idea to remove all starter gear from the mill, and, in the case of single phase motors, the start/run capacitors as well, and mount it all on a nearby wall. The vibration from these things, especially when the rollers get pitted, would shake contactors to pieces and wear through the cans of capacitors.
@brianmoooore I have soo many pictures like this from the last 20 or so years I'm glad of cloud storage!😄
Yes the wooden wedge bodge, I've come across that a few times. The last one was on an old floor scrape system and was swapped between the forward & reverse contactors when it got to the end of the scrape.
amazingly the capacitors apart from being shot were in surprisingly good condition, they were wrapped in a pink sleeve of some description and the inside of the metal case was rubber with cardboard around the caps (the cardboard had 2/2/40 written on it.) I need to find some new caps and a contactor to get it going again!
I bought a new handle for the boot carpet cover on my car, the thing arrived OK, but the springs and screws where missing, I contacted the seller and they came back with this: "We are sorry to hear you have a problem, can you please send a clear picture of the item" how can you send a picture of an item that is missing 🤡 answers on a postcard please. 🙄
I only link this video here because it highlights the awful state of electrics in other countries...I mean, those cables crossing the street> Plus, the string of lamps in the bar...what were they thinking? They are clearly dodgy!
Like minded electricians have obviously been watching this, hence it has more than 7 billion views...7 BILLION! Nick Bundy, eat your heart out!
It looks as though the middle two N connections at the meter are the opposite was around to normal, somewhat adding to the confusion.
From left to right at meter I think we have supply L, load N, supply N, load L.
Is there any main earthing going to the switched fuses on the left?
have to disagree there. looks likre N from fuse to Henley on the left of the meter, gthen into term;2 on meter. then terminal 3 to henley that's next to the fuse, then on to the circuits.
Even though I was there, I didn’t notice the neutrals… so I’m going by the photograph.
If the meter terms are numbered 1,2,3,4 from left… I see supply line from fuse into 1. Then neutral load going to the Henley to the left of meter from 2. There are outgoing neutrals from this Henley.
The neutral on 3 goes to Henley just above the fuse, which I’m taking as supply, next to earth Henley.
4 is load line
So I’m on the side of 2 and 3 mixed.
Not that it makes any difference, right? The meter doesn’t slow down or anything
i think the henley just to the left of meter is fed from the fuse, which would make the meter terminals correct.
and that could be a cracking upgrade by replacing the switches with a long slim din rail box with a new CU directly below. gland all the conduits into the ntop of the din rail box and extend with din rail connectors.
Accumulative earth faults?
That’s a lot of sockets on one rcd.
There is from the RCD going left.
40A cooker
40A shower
40A second shower
32A ring to 6 2gang garage workshop sockets
32A ring to 7 2gang sockets in an office area
32A ring to 12 2gang sockets downstairs
32A ring to 14 2gang sockets upstairs
32A ring to 9 2gang sockets in hall, entrance foyer and utility.
6A radial to boiler
16A radial to 3 x 2gang outdoor sockets.
So I’m surmising the RCD has been overworked a tad.
The customer had a N-E-L fault on their ring. The previous electrician had moved it off the RCD as a 'temporary' measure. I could hear arching coming from inside of a wall when the cable was live. Found this buried within the cement render. A previous spark had jointed a leg of the 2.5mm ring and buried it.
Not sure if it was the damp, a bad connection or a combination but it sure went pop.
I wonder if that was a underrated joint used and it’s let go over time? Either way it’s not special for the customer.
Neighbour knocked on my door this morning
looking a bit sheepish and shaken
“just changed a light and it works ok but gave me a big shock when I tried to put the cover on”
he had copied the original rose cable positions.
N - loop - live
to the new fitting that came with a terminal block
N - pe - live
the earths were all twisted together and not connected to anything.
took me a full 30 seconds to see the red wires in the terminal with the green/yellow and mentally compute that it looked WRONG!!!
to preserve the little self pride the poor guy had, I didn’t take any pictures.
I have a funny feeling a bottle of wine or case of beer might be coming my way.
N - loop - live
N - pe - live
I have seen the Perm lives shoved in the earth terminal a couple times , customers complaining when they touch the light they get a belt
basically the light fitting was acting like a make shift earth electrode
Last time I had a similar case (friend says he changed the rose and now it trips) it took me nearly 10 minutes to find the issue. After staring at the rose for ages thinking there's absolutely nothing wrong here and feeling stupid I finally found the CPC the switch end was in L2 at the switch. It had been all along. In those daft circumstances it actually matters which way around the two switch wires are connected the rose end!
Ummm
Yes looks like the plumber might have moved the socket down and put his tap where the old socket position was , OR the socket was already there and the tap was put direct above the existing socket
Chris the Plumber been in the area by any chance ?🙃
I think we all came to that conclusion a very short time after it was posted, the tell tale dust on top of the tap was noticed by Raptor straight off 🧐 still it wasted a few hours away from the damed jigsaw.
8K
Darkwood,
mainline,
