Reactions: ipf
Reactions: nicebutdim
Yeah, it's on the banjo, I know...but it does look like it screws into the solder..😀
It is a banjo a strange set-up but it is rock solid. Look lower down there is the original braid.
Some high quality skillz on show here. DIY Dave has out done himself with this job!
If you needed a tool, (ie, a hammer) to access that space…. Can it be classed as an enclosure?? 🤣
So they over clad the original ceiling by the looks , I often find those big transfomers feeding a bunch of 12v spot lights wired like that using twin flex and connector block
The issue is often getting to the transformer which is often inaccessible without mashing a hole somehwere
Reactions: timhoward
It’s a good job I’m only 6ft and 15st. Otherwise it would have been a really really tight squeeze to sort it. Instead of just the really tight squeeze it was! 🙄
But I did just about did it, without cutting the ceiling. 😇 Now I just need to clip the cables with some fire clips as best I can and wire in the new downlights.
I’m 6’, and there’s no way I’d be fitting in there without taking most of the ceiling down….
Hope that Artex did not contain Asbestos. 😱
All very well being flippant about it, but that ceiling coated in Artex had been Drilled, punctured and cut and could have released fibres into the loft space, I hope at the minimum you wore a mask when in the loft.
Reactions: Raptor0014
  • Funny
Reactions: Baddegg
I always wear a mask when in lofts. 99% of the time around my way they all seem to have the old fibreglass in which gets everywhere.
Unfortunately British gas install the yellow stuff as part of there free energy saving stuff. The brown knauf stuff is much better. Masks and overalls in lofts is poop in good weather.
thankfully my crawling days in lofts is over for good. i get my lung poison from Marlboro these days.
Just isolate a couple of wall lights before plastering, the builders said....
3 of these in a small house covering every light fitting. Was probably once quite neat and labelled - but had been added to over the years. Probably looked very neat back when it was all wire nuts...
Still, did avoid lifting many floorboards, so I can see the advantages of the system, if fully labelled!
And accessible.
Was there a screwed hatch in front of it…..
Is there still a screwed hatch in front of it???
Doing an EICR and found this. Newish build too at 3yrs old. Owner never had any paperwork prior to today and it’s going to be rented out.
Novel way to use a cooker socket for a gas hob igniter. So the gas hob is on a 32a circuit of its own. Plug wired in 6mm
Cooker/oven is on its own 16a radial with the fridge.
8K
Darkwood,
mainline,
