- Reaction score
- 8,238
Pretty much every celeb sparks on Youtube and every celeb diy training video on how to do a board change shows the sparks using an impact driver
When did this become the norm ?
Discuss when did the impact driver become the tool of choice to do terminals up ? in the UK Electrical Forum area at ElectriciansForums.net
Remember getting a "good hiding" for knackering my old man's. Think it was either light sabre or sonic screwdriver related tomfoolery.
And at the point of impacting will it have reached the correct torque and what happens in that split second etc where its still running ? A small drill with controlled torque points and a nice action trigger is still superior as it will stop when told to !No it isn't, it has a variable trigger or mine does.
It also doesn't "impact" until it reaches a certain resistance which engages the "hammer".
The "hammer" is actually two parts, one anvil attached to the bit holder and another spring-loaded anvil is driven by the motor. Only when enough resistance is met by the fixing will sufficient torque be applied by the motor for the spring to be compressed allowing the the anvils to ride over each other and apply the hammer action.
There's some good animation in this video that shows the anvils in motion.
I don't have this exact model and have to rely on my finger.
You can be surprisingly subtle with an impact before it starts to impact.
You don't get anywhere near the point of impacting, it's called trigger discipline, the more you practice the better you get.And at the point of impacting will it have reached the correct torque and what happens in that split second etc where its still running ? A small drill with controlled torque points and a nice action trigger is still superior as it will stop when told to !
Dusty I can’t answer that but the young bucks have all there tools that is battery powered. We didn’t have technology in the old days. I’m not sure if they know how to use real tools without batteries.
I think is the problemDusty I can’t answer that but the young bucks have all there tools that is battery powered. We didn’t have technology in the old days. I’m not sure if they know how to use real tools without batteries.
W.T.F?I think is the problem
The other day I watched a young lad trying to change a plug top using his 18v impact drill
So unless you finish with a torque driver .How do you know you are within the level the RCBO is made for etc ? With a drill set with different torques , you can measure each...Or as I did , email festool and ask them !! Chances are if you took 100 people and asked them to use the festool and a impact , they will get it a lot closer with the festool etc ? As they cannot make the drill go past each setting just by using the triggerYou don't get anywhere near the point of impacting, it's called trigger discipline, the more you practice the better you get.
I can fix a plastic back box with it as well and without smashing the living love out of it.
My dentistry with it is still a work in progress though, not many willing volunteers to practice on.
So unless you finish with a torque driver.
Don’t tell me you use an impact driver!There is, after all, more than one way to skin a cat.
I agree! I just think a drill with 1-11 torque settings is a better optionI think my first/second post on this thread states that's exactly what I do.
Because my torque screwdriver is calibrated and the correct and recommended tool.
If that works for you and gives you the correct results then crack on but don't assume someone doing something differently to you doesn't know what they're doing.
Not always I but have, in combination with a torque screwdriver.Don’t tell me you use an impact driver!
Still as rough as a Badgers wotnot way of doing itNot watched… but is it an impact, or a torque setting on screwdriver?
I think you can get torque adapters for battery drills/drivers that are as exact as the hand held torque drivers from WERA/ WIHA ….. which is the preferred method of tightening terminals
If he is a Butcher he still does, but knot knowing him I can't be sureDon’t tell me you use an impact driver!
I'm trying very hard not to picture where exactly you put the torque driver while you skinned the cat with the impact driver.Not always I but have, in combination with a torque screwdriver.
Celeb Spark??????????????? Celeb Money grabber you surely mean Mate, cus most of these "Celeb Sparks" have a cheek calling themselves Sparks, the Trade is dying a slow death.
Couldn't agree more and the slow death is rapidly speeding upCeleb Spark??????????????? Celeb Money grabber you surely mean Mate, cus most of these "Celeb Sparks" have a cheek calling themselves Sparks, the Trade is dying a slow death.
Some of the new build lash-up wiring i have seen over the past 5-10 years , the trade died along time agoCouldn't agree more and the slow death is rapidly speeding up
Bloody disgraceful, definitely saw the best times in the late 70's to the late 80's IMOSome of the new build lash-up wiring i have seen over the past 5-10 years , the trade died along time ago
One question I seem to get asked more frequently these days is "are you a proper electrician"Some of the new build lash-up wiring i have seen over the past 5-10 years , the trade died along time ago
You mean when being an NICEIC approved contractor actually meant something and was something worth havingBloody disgraceful, definitely saw the best times in the late 70's to the late 80's IMO
The NICEIC's defined scope approval was the start of the slide it was then accelerated by the Domestic Installer schemeThe Domesticated Installer scam Killed any prestige the trade once had , giving a title to DIY sparks was a real killer
This is true, you know because like me we were there in that era.!! The trade is unrecognisable as we knew it.One question I seem to get asked more frequently these days is "are you a proper electrician"
I started within the trade in around 1997 and as a young apprentice I wore my NIC branded uniform with real genuine pride, it made me feel like a real tradespersonThis is true, you know because like me we were there in that era.!! The trade is unrecognisable as we knew it.
I enjoy the trade and the more difficult challenges it throws up from time to time I don't see a time where I will fully retire but I will pick and choose what I do and when I want to do itI love this trade but I am glad I only have about 5-10 years left in it before I can pack it in
Would have though a multi-tool would be better suited?Don’t tell me you use an impact driver!
....and when the 239* was actually technical and required acknowledge working knowledge and ability to recal information and not just find it ina book........I'm sorry where were we going with this again?You mean when being an NICEIC approved contractor actually meant something and was something worth having
Reply to when did the impact driver become the tool of choice to do terminals up ? in the UK Electrical Forum area at ElectriciansForums.net
