- Reaction score
- 8,198
Pretty much every celeb sparks on Youtube and every celeb diy training video on how to do a board change shows the sparks using an impact driver
When did this become the norm ?
Discuss when did the impact driver become the tool of choice to do terminals up ? in the UK Electrical Forum area at ElectriciansForums.net
a Diyer doing their own board change could seriously mangle the terminations using an impact driver
Some people are a wrong tool!I think the problem is that some people use the wrong tool!
My biggest bug bear as well.The misuse of the impact wrench in the tyre bay is one of my annoyances they run the wheel nuts / bolts on to overtight and then use the torque wrench that instantly clicks to confirm the right torque. I remember many years ago stopping to help a woman that had a puncture the wheel had been fitted a few weeks before and the standard wrench in the car wouldn't move the wheel bolts, I always have a long 30" breaker bar and a selection of sockets to fit wheel nuts in my vehicle so expected it to be easy to get the wheel bolts moving and it wasn't I ended up jumping on the bar and eventually got them moving I suggested she got some new bolts as they had been excessively overtightened and used a different tyre bay to get the puncture fixed if that was the way the one she had used fitted wheels
BUTCHERY, Cowboy practiceDeja vu anyone?
Impact Driver Vs MCB
Every big build I have had the pleasure to work on the last 10+ years I would say 99% of the sparks use their 18v impact to do the consumer unit connections Good practice as its fast and effective Or butchery and will lead to knackered switch gearwww.electriciansforums.net
So if you’re using anything other than a hand held torque screwdriver, or adaptor, then you are not following manufacturers instructions…Yes, L-S, from the video linked above,
Yeh… I’ve got one. Hardly been used.You can get electric screwdrivers specifically designed not to over-tighten terminals such as this:
But not cheap!E-screwdriver, starter set speedE® I electric
Product description Anyone who spends much of the day fastening screws knows how much time it takes and the considerable strain it causes to wrists…www.wiha.com
It's more a case of using a impact driver as a powered screwdriver. Tighten to the point the cables are held then run down with the torque driver.
Its how a impact works.... its not smooth or subtle .It smashes its way until its stopped . Drill has far more control and less chances of damageIt's more a case of using a impact driver as a powered screwdriver. Tighten to the point the cables are held then run down with the torque driver.
It takes a lot of strain of the wrists.
Now, I know some will never accept it but its not really all that controversial. You can rip the guts out of an MCB terminal with a hand held screwdriver, you don't because you don't over tighten them, exactly the same with an impact. You just don't rattle them.
Reply to when did the impact driver become the tool of choice to do terminals up ? in the UK Electrical Forum area at ElectriciansForums.net
