Currently reading:
What is maximum current of the mains?
Discuss What is maximum current of the mains? in the UK Electrical Forum area at ElectriciansForums.net
Hi,
What is th emaximum current draw allowable from the mains for...
UK domestic single phase
Light industrial single phase
Light industrial 3 phase
If there are different levels, then please advise.
Basically i suppose what i am asking is what current does the wiring have to be rated for, and what is the breakers tripping points.
Am i right in saying that single phase in UK for domestic is either on a 16A circuit, or a 32A circuit.
And that its the same for light industrial.
And the industrial 3 phase is the same...but that current in each phase?
100A is a normal domestic supply in the uk
same for light industrial both single and 3 phase
however, anything is possible if you ask and pay for it.
I have never come across a supply for industrial that was over 400A per phase.
any higher than that and generally they will push you to a High voltage supply instead.
The wiring is always rated according to the protective device (fuse / breaker) before it.
Domestic properties tend to have 60,80 or 100 amp supplier fuses.
Industrial / 3 phase can be considerably larger.
It's common to have circuits ranging from 6 amp circuits for lighting to 40 amp circuits for an electric shower. The wiring would be different sizes for each.
Thanks, and please advise, if you have a 3 phase supply 230VAC, and each phase is 60A rated, then you can supply a max power of 3 * 60A * 230V = 41.4kW?
Sort of.
There is a thing with alternating current called power factor.
If your load is resistive, such as an immersion heater, then yes 41.4kW.
If your load is a motor or some other things, although the amps x volts = 41.4kVA (kilo volts x amps) the actual power may only be 80% of this so 33kW.
This is a rather technical aspect of ac system we use.
Reply to What is maximum current of the mains? in the UK Electrical Forum area at ElectriciansForums.net
