And here is the problem with the TT Rod
Is that shiny thing the snapped off bolt? Bit of a clean-up required and you might stand a chance of not getting the chisel out.
Looks like the cable is not attached to the rod, cable on one side, lug on the other?
I’ve sorted it now.
What's the RA like, just out of curiosity I'll take a guess at 116 ohms.
I wouldn't bother digging it out, I would just screw a new top lid on it.
Not far off.
Customer - 'I have removed the fluroescent light in the garage and 'hooked up' the lights you took down from the lounge with a sensor'
Me - 'so what do you need me for?'
Customer - 'It dont work'
Why, when I hear the words 'Hooked up' do I shudder?
there was a huge loft access above the garage
At least with customers like that, you will always have work boyo 😃
Such a shame about the missing trim - really takes the shine off that job.
There are two things that spoilt the job one is not painting over the wires and the other is not using led lamps otherwise a top effort.
whats the problem? Theyve used WAGO's 😀
  • Funny
Reactions: Jim_e_Jib
To add to the chaos, did the fan just vent into the roof space too? That is assuming it actually operated in any meaningful way...
He would have ducted it, but there's no space with all those cables.
So which one of us is up early and which one is up late?
8K
Darkwood,
mainline,
