Darkwood
On with running a supply to a car ramp via an oldish 3x3 trunking, today.
Originally there were some fluorescent fittings fixed with bush and locknut system, changed to LEDs in the last couple of years.
To remove lid, I had to cut some cable ties wrapped completely round the 3X3, used to secure the lid, I presumed. On snipping, the fitting dropped, lazy twerps used the ties to hold the fittings up.
Not even put a locknut on that original bush.
Fitting taken apart and the cables have been extended with T+E....so obviously done on the cheap by domestic dummies.
This place is going to take some work. In addition to the pics below.
No earth to gas or water
Undersized main earth (it’s a single 2.5mm copper strand)
Consumer unit is Bakelite & Wood under the stairs and cover is damaged
No RCD protection and no supplementary bonding of any kind.
Boiler is also wired wrong as it fires up if you turn the hot water on. But doesn’t when heating is turned up. It is also supplied from the socket circuit and the immersion circuit.
No CPC’s are sleeved (trivial given the other issues)
T&E feeding the garage is supported by a washing line and i have an inkling it’s been used to hang washing as there are marks that look suspiciously like peg marks!
Pipe jockey also needs to come in as when the boiler does fire up, only the rads upstairs get warm, downstairs stays cold.
Bet they’re gonna wish they never asked me to come in now. I’ve got 26 observations so far with 15 being C1 & C2’s
Just an observation, normally if the rads upstairs are heating and the downstairs are not, it's probably the pump is not working.
I did wonder. But it’s a new pump well it’s certainly shiny in comparison to the dust covered stuff in there and it’s digital.
I’ll wait to hear what the pipe jockey says. I think the landlord is a going to be upset at the remedial bill just before Christmas. 💷💷🤷🏼‍♂️
8K
Darkwood,
mainline,
