B
blennymar
Please help me how to wire this, it’d be awesome if someone draws a simple diagram like the pic I posted but for my parts, I saw a diy video on YouTube for this mini subwoofer but it’s not clear where all the wires go. It’s only clear for the one speaker set up here in the diagram pic but there’s no diagram for the 2 speaker set up.
These are the parts used
1.mt3608 dc step up converter
2.18350 lithium battery 3.7v 900mah
3.dc 3.7v 5v 3w audio amplifier board
4.3.1 type c connector 5.5v 1a type c micro usb charger
6.4ohm 5w speakers
7.on/off switch
Does it say what impedance speakers the amplifier is suitable for driving? Also what impedance are your speakers? (they will probably be marked 4 or 8 Ohms).
This will decide whether you wire your 2 speakers in series or parallel.
Reactions: blennymar
I really don’t know, I just know the speakers are 4 ohms. Here’s a pic of how the guy wired it all up, but I can’t tell where all the cables are going. I can post a link to the video if that’s allowed, y’all would definitely know how to wire this if you see the video, but I’m a noob still.
Thanks for the reply 👍
That picture shows a different amplifier board - it has 2 speakers outputs.
Having said that, you can connect your 2 speakers in series to your amplifier:
Amplifier --> speaker 1 positive
Speaker 1 negative --> speaker 2 positive
Speaker 2 negative --> amplifier
Your pic of your red circuit board shows the speaker connections are the white sockets, labelled Lout + and - for the left speaker, and Rout + and - for the right speaker.
The latest photo from the video shows the other side of that circuit board with the speaker connections directly soldered to where the connectors are on the other side of the board.
So either use the connector if the mating parts are supplied, or solder the wires as per the picture!
sorry DPG - I was still composing when you posted! - I think they are the same board!
Apologies, I missed the red board on the left.
Listen to Avo and not me!
  • Funny
Reactions: blennymar and DPG
But what I didn't say is that the first block diagram of how to wire it all up, is not the one you need.
It doesn't show the main red board you have (which appears to be the receiver/amplifier), or how to wire the remaining (presumably power management) boards together.
Is that all the circuit information they gave you?
I think it would be OK for you to post a link to the video, which might help unravel this!
But that’s exactly what I mean the first diagram is just an example of what I wanted, but for my set up, idk how to explain it my bad, what I want is someone that can draw a diagram like the one I posted but for the parts I have, I’ll try to make an example, I’m just not good at explaining
I want something like this, I only know where the ones I drew go though, if they’re even correct.
OK I understand better what you need now.
I've looked at the modules you have, and I'm not sure why you need the MT3608. You might get a bit more power if you used it, but to safely use it I think it would be a good idea to use a multimeter (well, voltmeter) to set it to the correct output voltage.
Your battery is 3.7Volts. The amplifier runs from anywhere between 3.7V and 5 Volts. The MT 3608 power module boosts the battery voltage, adjustable via potentiometer, up to 24Volts, which may damage the amplifier if you turn it up full.
So if you want to use it, you will need to set the output voltage of the MT3608 to 5V before you connect it to the amp.
I suggest you try the amplifier without the MT3608 module, at least to start with.
Basically what you have drawn (in your first post) is correct. Combine it with what you've put in your second sketch (Leaving out the MT3608!)
I hope you can follow my description below, instead of me drawing a diagram, but I can do that later if you need!
I'm assuming you have the flying leads with connectors that came with the amplifier (shown as included in the ad I looked at) but if you haven't you will need a soldering iron!
Wire the battery, USB charger, and the red/black battery cable with the red plug, all as you have drawn. But using your red amplifier PCB instead of the one in your first drawing.
Then solder, or connect however you can, the two white speaker leads with connectors and plug them into the white sockets on the amplifier pcb.
I think that completes the wiring, so charge the battery and see if it works!
Let me know if I've missed anything!
PS: to get any reasonable sound out of the speakers you will need to mount each on a baffle, or in a cabinet or box of some sort.
This is awesome info, but if I understand correctly, to push the speakers to its limits, I need to use the MT3608 right? I really wanna use it, and I do have a voltmeter so I can set it to 5v 😁👍
Yes the speakers do come with the cables, I do have a soldering iron though and I’m very good at soldering I’m just not good as an electrician that’s why it would be easier for me to just follow a diagram 😬 lol, all I know is how to wire is leds lol. If you do draw a diagram, I’m not asking for anything professional just something very simple 😁
Here’s the link to the video, if you have time to watch it you’ll understand way better exactly what I’m trying to do,
not sure if links work here. And yes I’ll make a mini subwoofer box like in this video, I just need to understand how this little set up needs to be wired then I’ll buy multiple of the same parts and make the same set up but with many different subwoofer boxes and all that.
This info is gold to me really I really appreciate it, if you don’t have time to draw the diagram using the mt3608 I’ll just try what you said but I have time to wait :D
Reactions: Avo Mk8
So in the video (but not included in what you see) the constructor has de-soldered the USB connector on the 4056 battery management board, and he uses a separate c type connector pcb which he mounts in the side of the cabinet, but it's not possible to see all his wiring.
I could guess, but I won't.
If you want to use the c connector board that you've got in place of the usb already on the 4056 board, I'm afraid you'll have to work that out. It should be just usb power from the c-type to the corresponding polarity pads the 4056 USB connector was removed from.
I also note in the video the switch is single pole two way - is that used to switch between Off/charging and On?
Yours is single pole on/off, so I've put that switch on the load side, leaving the charging permanently connected.
Initially it might be safest to take the power for the MT3608 from the power out tabs on the 4056 board instead of directly from the battery. But once you start using this in earnest I suspect you will need the oomph you can get directly from the battery to drive the speakers, and I don't know what current limiting properties, if any, the 4056 charging board has.
Do be careful, lithium batteries can release a lot of energy and you don't want to be shorting it out and causing an explosion or fire.
If you see alternative, or completely different, suggestions out there, feel free to adopt such!
Actually on the issue of safety, if it were me doing this I would put a fuse in the +ve battery connection as near to the battery as possible!
Wise words there about exercising caution around the lithium battery, especially when charging it or causing an accidental short circuit.
I’m not sure if I’ll use the seperate c type connector but yes I noticed he took it off and used a seperate one, I might just use the original since that doesn’t affect anything but the placement.
I’ll probably order the single pole 2 way switch so it’s the same, would that make it any safer though?
What type of fuse would I need?
Didn’t think this could be that dangerous 😬
Good idea
If you had a centre off 2-way switch, so one way was charge, centre was battery disconnected, and the other way was "On" I guess that might be safest.
I'd suggest a 5A
I recommend you do a bit of research on the safety of Li cells. Don't short or persistently overcharge your cell, and please don't muck about with them as some YouTube video's delight in showing!
Good luck with the project.
Good idea
I'd suggest a 5A
So this switch in the pic should work better right?
Yeah I’ll do some research on that, but the little set up from the video I linked is dangerous?
I’m just unsure if I will be able to wire everything with the center off switch and the fuse since it’ll change the set up a bit.
It won't work 'better'. It would just be a different way of doing it! But I understand what you mean, would it make your speaker setup better? It would mean you could turn the unit properly "off", whereas in my sketch the charger is permanently connected across the battery, which I think should be OK, but I haven't seen any technical info to justify that assumption!
The setup is not "dangerous" any more than any product containing a lithium battery is dangerous. I was trying to warn you that constructing electronics with a lithium cell or battery can be dangerous if you don't take care In what you are doing while you are building it.
There are many instances of lithium batteries catching fire and/or exploding. I just want you to be aware that you must not short the terminals of your cell together, or vastly overcharge it, for your own safety. You owe it to yourself to understand what you are getting into, so you don't accidentally injure yourself!
Putting an in-line fuse in the wire from the positive battery terminal before it goes off to wherever the circuit shows is hardly a significant change, and would provide protection where at the moment there is none.
I would just like for you to educate yourself about the potential (!) dangers of batteries. Just because your project is not using mains electricity does not mean there are no hazards!
Awesome, I’ll buy the fuse and the center off switch and finally try to wire it all up. Thanks for all the advice, and yeah I was aware that these batteries can be very dangerous but I actually forgot, thanks for the heads up 👍
I’ll post it once I try it all out.
Reactions: Avo Mk8 and DPG
So I’m trying to set the step up converter to 5v and for some reason it only lets me go down to 6v, Is my voltmeter a cheap one and just not reading right or maybe I’m doing something wrong? I tried turning it both ways.
How to wire these mini speakers?
DIY Electrical Advice
blennymar,
blennymar,
