Darkwood
Notching the joints was the plumbers way, and I think electricians back then followed suit, and probably still do to a certain degree, as sometimes needs must.
Brings back memories though of live nails poking out the floor, or the missus shouting up the stairs that there's water dripping from the ceiling.
If that wiring was staying, I would notch some nail plates into the floor board, better than having to junction box the cables just to divert them through some joist weakening holes.
I still have a load of "SafePlates" in a box somewhere....
I think some cowboys/ plumbers fitting showers think as long as the live is tight, it’s all good. Neutral isn’t that important, is it??
Always seems to be neutrals… with pull cords as well. And it happens with 7kW as well, but doesn’t make as big a bang as a 10
Wait until everyone’s EV charge points start melting… oh wait, I’ve already had one!
I never had a problem with 50 amp Crabtree pull cords, double terminal screws helps.
Some charge points have very low torque setting for supply cable - astoundingly low and I tend to spend a bit of time getting stranded conductors bedded in before torquing.
Should have tightened that neutral another half turn. :)
Worked in a large government building where majority of lighting was wired in blue, black and earth single, blue being phase and black neutral. The sheer amount of fittings with reverse polarity was scary.
are you sure it wasn't black line and blue neutral?
most fittings can work reversed.... its just when line somehow gets connected to cpc that things get tricky... as the upside down sticker in the picture would could lead to
Had similar last week. Building from around 2000, with emergency lighting using black for neutral, red switched live and blue permanent live. Strange thing was this was all in some sort of shielded flex, so I couldn't understand why these colours were present.
I thought it was originally but traced it back to find the circuits wired in red, yellow, blue singles with black neutral. All fittings had been changed to led and working with reversed polarity. Only realised when we went to test.
That's a strange one. Was there a yellow in it or just red/black/blue?
8K
Darkwood,
freddo,
