Hi,
I trying to figure what is wrong with horn on this car. Its 2022 Pathfinder. Horn works when i ground connector 30 pin 10 (connector that goes to clock spring). In steering column green wire that goes to air bag does not have any voltage. I also checked there is no continuity between pin 10 on connector 30 and connector 149 pin 24 (connector going to steering wheel and all accessories).
I have original clock spring and new one that i just got from the dealer. On both no continuity between those pins.
I am attaching diagram and connectors pin out. If anybody has any suggestions please let me know.
Thank you
Thank you
