Guest viewing is limited
2 third year JTL apprentices and I spotted them doing this!!
And people wonder why the industry is going down hill!!
Well, .....At least they have a bending spring in that plastic pipe. Maybe someone here can try it out for themselves on Monday, see if it does work!! lol!!
Ok how many of us have
1 burnt our hands rubbing the PVC conduit to bend it
2 Can't get the spring out without geting lumps under your neck
3 Bent the bloody thing wrong in the first place
4 Still get that nice kink on a 90 bend ........................
Me! Me! Me!
I think I can feel one of my headaches coming on....
I know a lot of old skool sparks frown upon it, but i mostly use the preformed or inspection elbows, just to make my job look neat.
Is it because the conduit wall thickness is thinner noadays that makes it kink?
Manufactured joint, bends, sets etc are there to be used mate, don't think I'd give a monkey's what some old timer thought of me using a manufactured piece. We're sparkies NOT Joiners - and all old school should know the real difference between a Joiner and a Chippie.
I wouldnt fancy having to lump that steel conduit bender around everywhere just so I could bend a bit of plastic. I prefere to do my own bends rather than the manufactured bends. I think they look neater and are easier to push cables around. But that is just my opinion.
As a further note to the topic matter of this post - have a look at a recent post by Jake1990, asking 'Qualifications needed to become a domestic electrician only', just a question that says it all to me.
5 knocked someone out when pulling a stuck spring out ?
6 cursed at gaffer getting wrong gauge conduit n spring
7 Snapped pvc in the cold
I rewired a dog kennels and cattery a few years ago, all in PVC conduit.
Some of the work was done through the winter, and the amount of times it shattered for a 90 is unbelievable!!!
Almost took out a couple of members of staff :D
Amp are you bending them too quickly? Maybe not warming them enough? Or are you just bending with your hand and not over something like a knee of a form? The way I do it is rub them so they are nice and warm, and go for a slow but smooth bend, across the knee usually. I find if you stop too many times when bending it starts to kink out.
If you do all this and it's still kinking, as you say your spring is too small. Did you buy a spring for conduit or are you using a plumbers spring? I don't know if these are different, just a thought.
All of the above.
FWIW - we insist these days that all changes of direction are done using manufactured pieces - though we set other angles. Like other posts, we find it gives a better job.
Low powered heat gun, spring, former, slow bending motion. Should see you OK no matter the angle. Though I will say 91 degrees on an alleged 90 degree bend looks shocking too - there is a real art to bending 90 degrees in plastic and making it look good.
Common causes of kinking are too much heat, not enough heat, to fast a bending motion, and trying to change the angle once you've started.
All that said, I had a guy on one of my projects, way back in the day, who seemed to be going for the world record in putting sets into galv conduit - I counted 14 on one three metre length, and he wondered why I binned it.....it looked like a bit of bloody spaghetti, even though it followed the right lines, he couldn't figure for the life of him why so many sets in one length was a bad idea......
Sigh.....just one of the many areas we do not, IMHO, teach our "apprentices" enough (or really at all) any longer. I recall my days on site - I think, when I was still at a point of thinking that no REAL man would dream of wearing ladies tights....(the things you do to stay warm on a site in - temperatures, huh?) and getting told that containment was the masterpiece of a real electrician - any t&%t could run cable....but running it in containment that was properly set out, properly jointed, properly everything - and LOOKED right everywhere - that was art.
The guy that taught me was a master of Pyro, galv, trunking, tray, you name it......but I recall even he got a kink or two in plastic.
Tights? What's wrong with longjohns, or even a ski base layer if you're a ponce?
Suppose you must be secure with your sexuality lol
Utterly secure mate....
Until I met my now ex, I was sure there was only one d8&k in a relationship, that said....
Way back in the 80's, when electricity was only just being invented, mate....tights were it....you had a pair of longjohns, pair of tights and two pair of jeans. Skiing - that was something you didn't do on £30 a week.
You young 'uns don't know how easy you got it these days LOL!
Thats right, but why do my right angles always kink. Shouldn't matter what quage it is should it. Is my spring to small?
By the sounds of it, the diameter of conduit I think your find is the outside rim, so the heavy gauge as thicker wall, so it will thicken slightly in inwards I think.
Ill check my springs tomorrow and let you know, Ive got heavy and light for 20mm and 25mm.
Cheers Rocker,
Believe me i taake my time and always bend over my knee. I've even tried a warm air gun when the day is cold but still ends up going pear shaped.
Picked up the spring from my wholesaler, so unless hes fooked up when buying, i just don't know
Birmingham
And we wonder why the future of our industry in bleak
Australia
High Tower,
whats an rb4,
