J
james king
hi all i have changed 6x gu10 downlights in a kithchen as the down lights befor kept blowing there were LV.
what may cause the lamps to blow regualy eg only 3-4 hours of being on? all suggestions would be grat
Most likely rubbish lamps.
Second most likely insufficient ventilation.
Check voltage is within acceptable limits as well
Insulation over the top?
In the end if quality lamps are fitted to correct fittings with adequate ventilation,acceptable voltage and not subject to vibration etc they will last a reasonable time.
both the LV
and the GU10 lamp blow after about 4 hours four of the six go. there is clear ventilation no insulation over them. the new down lights are fire rated. all test seems ok >99 IR and 0.89 R1+R2
lamps genarally have a tolerance,sounds just like poor quality lamps,halogens are so hit and miss,some last years,my bathroom ones have lasted 8 years(hope i dont tempt fate here)no failures,others like my kitchen go regular,although they might look pretty,downlights can be a real pain,the next client to ask me to fit a load im gonna recommend led spots as the saving over time pays.
so i think what i shell do is do a continutity test between L-N and N-E so test for loose connection? what do u think. i fitted 6x low enegry lapms when i fitted them and they did not blow!! but she didnt like the light and wanted GU10 buls insted since then 4 have gone
Are you sure they are only lasting a few hours?...customers often say they have only lasted a short time when in reality they have got mixed up with what has been replaced. A loose connection serious to cause lamp failure would almost certainly produce noticable flickering.
I would still suggest it is lamps..(see robsparkys post)....try a different batch of a quality brand and get the customer to keep a plan of which lamps blow and when.
hi all just to let u no i have been back and its not the lamps. they are fine and so are the fittens.. who ever wired it befor have done some thing wrong.
i have 230V between L&N
230V between N&E
0V between L&E
230V between N&E
0V between L&E
Wrong polarity....the N and L are reversed......needs rectifying but wont affect lamp life.
gu10 mains lamp blowing
Australia
james king,
Farmelectrics,
