Is there any emergency lighting? If so, I'd be happy to leave the RCD uncoded.
You can make mention of the wooden-backed Wylex in a covering letter but in the (literally) hundreds that I've encountered, I've never seen a problem yet!
There is Emg lighting yes, will note the boards in the covering report letter , was just wonering as the rcd trip tests would sudgest it needs replacing( never explained that sorry), so just change the main rcd up front and this will be fine then, its just many people say this is bad practise, but i assume the emg lighting would cover the total lost of light issue.
