Currently reading:
**Show Us Your Installs!!!**
Discuss **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
S
Spudnik
Right chaps,
Due to a few unavoidable issues, we have lost the original thread and pics etc.
Sorry about that!!!
So, if you want to re-upload your pics then great, if not, give us something new!
Cheers!!
fitted a small consumer unit today for audio equipment :)
Hi Si, is that a black Henley block with the tails going to your isolator? How did you terminate the tails from the meter into it? I was maybe going to have to do that a few months ago but never done the job in the end. Does the power supplier have to send sparks out to do it?
I Installed 2 of these and i service them monthly, can you guess what it is? ill give you a clue, it uses 20+ different A/C and D/C voltages, from 5V to 700V and everything you can see spins at 3 revolutions a second....
main board
Done this noard when doing addition in house
Central heating and both 10mm to gas and water plus radial circuit connected when wired that day
16amp was used fo radial and six for used for heating. Company keep an eye on spare rcbos making sure they are not swapped for blanks
earth 11 was earth to gas which was getting took out when I wired the new 10 mm to gas that day
16amp was used for fire and six for used for heating. Working with a local authority so they keep an eye on spare rcbos making sure they are not swapped for blanks
i was being a arse really, to many beers and nothing to do ! but notice the cpc for circuit 6 is in terminal 8 !
Whoops me bad apart from that its passable considering some on the ones we come across. Open a board and its like spaghetti junction and the test sticker is from a week ago and u have to try and connect a new circuit to it with great difficulty
whats the deal with the RCBO earth connections in the DB? never seen that before, but dont work on domestic.. i was always told that RCBO earths have to go into the same connection as the CPC for identification, surely the RCBO earths need to be numbered?
Reply to **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
