One to confuse you all!! | Page 7 | on ElectriciansForums
Discuss One to confuse you all!! in the UK Electrical Forum area at ElectriciansForums.net
A
axel132132
Right then this has now happened to me twice.. and ive not a clue whats going on so if anyone has had the same issue it would be good to see what causing it.
Anyways SO i have a 2G2W light switch upstairs and a 2G2W light switch downstairs.. I Wire them both correct.. Up have Brown from 3-core in Common, then black in L1 and grey in L2 and Live in in L1 and Live out in L2.. that controls the lights on the stairs..
Then i do exactly the same with the upstairs lights. Feed in, feed out L1 + L2 etc.. ok all simple so far..
NOW COMES THE CONFUSING BIT..
The stair lights are working fine on the 2-way wikid..
The LED spotlights in the celing dont work.. OK
SO i swap the cables, basically swapping the switch.. NOW the LED spotlights work on the 2-way but the stair lights dont..
OK so maybe the switch is broke.. Change the switch (TWICE still dosent work)..
Umm maybe i have a strapper down or something.. Bell out the strappers.. BELL OUT FINE.. ok now WHAT the hell is going on here??????? Switch is fine, strappers fine and if i move the strappers from one switch to the other it works so this proves that the Live IN to switch and the Live to the light works an that all the lamps are working..
any ideas anyone?
cheers
Shame there is no update, given the amount of useful replies you would have thought that that would be the least he could do - or maybe he'll never update us and just load a new question and move on.
Does anyone know where I can get a copy of the new regs with the second amendment..
No hahaha, but I have several 17th edition regs books here which are out of date, the Opening poster can have one if he wants it, I ve never looked at them, everytime I buy one some prat in london in a suit decides to bring another edition out, I still have my 15th somewhere, that has a second amendment, who decides what colour to make the front cover, :biggrin5:
- - - Updated - - -
He's still working on the 2 way switching problem he encountered a day or two back I suspect.
It's not going to be easy trying to find a fault especially when you know you've connected it all 100% correctly, and gone the extra mile by taking a bit extra time to carry out a Tug Test too.....can't wait to find out what it turns out to be
Broken tester, the Common link brown of 3-core belled out fine with my tester.. But when i put pressure on anything with the probes it belled out fine.. I pressed one down on a wall and the other on my arm and it said it was a circuit
SO the issue wasnt as simple as all put out to be, cable belled out fine BUT due to testers being broken wasnt fine therefore that was the issue
Sorry for late reply been busy
Reply to One to confuse you all!! in the UK Electrical Forum area at ElectriciansForums.net
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
Thank you! I didn't realise the wiring was QUITE that old… I'll replace it carefully.
Recommended Sponsor News
Hi everyone,
