Well there you go then, continue on, in your own sweet way, and don't give a dam about the Ra values or system stability!! lol!! Doing things properly in the UK, has long since past it's sell-by date anyway and with this sort of attitude will continue to do so!!
And also those whose views may differ greatly but who are also very capable of making an informed and educated decision as to whether or not it is done 'properly' in their own right :)
Are you putting yourself in that last catogory?? lol!!
Said the guy just out of a 17 day training centre course, to the fully qualified time served 25 year veteran!! lol!!
And before you start throwing your rattle about, ....No i'm not saying ''You'' are a 17 day whizz kid!! lol!!
You are fully entitled to your opinion! And although I may not agree with you I will defend... hmm, maybe not to the death... but I will defend your right to say it lol. And no, I didn't think you would be referring to me as a 17 day whizz kid so no toys out of the pram just yet haha! Although the implication means that I'm holding one ready!
I think the 1667 is stupid, it's like someone saying phew at least the RCD will work quick lets go..........It's like going back to previous versions of the regs 15th if memory serves me correctly and using the "alternative method" 50v rule ............personally I would feel much happier if everyone aimed at as low ra as they can, much lower than 200. I for one would be aiming at well below 10 ohms at the very least. If the DNO could only give us 10 ohms on TN supplies there would be an outcry, we'd all have to fit RCD's at every installation's origin. I've worked on many large sites over the years and the engineer on site would never except a ra of 200 let alone 1667 they would always be aiming way lower than 100. 5 - 10 would be accepted after some hard graft but as has been said it's possible to achieve below an ohm in a lot of cases with a bit of hard work with some decent rods. Lower the better IMO
I've never thought for a minute that relying on a sole RCD for fault protection is a good thing, but if you have two, one being there as a back up then I can't see the problem with a high but stable Ra value?
My thoughts are either, go for TN values and you might not even need an RCD, or, if it is unreasonable for you to do so, rely on two RCDs. I have never understood the logic of going for (but not quite achieving) TN values when you are still also relying on two RCDs? This is completely and unneccessarily over the top IMHO.
I dont disagree up to a point and I think you will find Skelton doesnt either.
The issue constantly raised by us is that many who scoff at the Bs7671 max values appear to be happy with values which will still not operate an OCPD in a reasonable time, if at all.They are still reliant on an RCD.
Given that a value of 10 ohms or 200 ohms......or even 1667 ohms will make no difference to RCD trip times why aim for a lower value unless you get TN values?
Hang on for a few minutes there lads ....................... I need to go for a pee and another bucket of popcorn. :)
An earth rod resistance of 10 ohms, I think you must be living on the fens in Norfolk. I know some areas can produce a low reading,but you go to a place with made up land and you'd struggle to get anywhere near that.
Using your argument, One could easily ask WHY would you be giving a dam about Zs values on a TN system, if your both so confident that an RCD will ''Always'' fulfill your Zs requirement to trip the OCPD?? That argument (which i also disagree with) is just as valid as you blindly accepting a 200 ohm Ra on a TT system because a Reg vaguely say so ...
As i've stated many times here, if i had installed a rod position that gave me a 10 ohms value, another rod would ''always/automatically'' be added, you have would to be a bloody fool not too!! And yes, it is more than possible in many instances to achieve near TN values, but that takes a bit of time and effort and knowing what your doing. But again, that's something else that has been lost in time and space!! lol!!
Yes you can get over situations with the use of RCD devices, but at the end of the day, it is just a substitute, it's not really a valid TT system, even more so if you haven't even tried!!! I've been involved with far, far too many TT systems of every type and description, in various countries and locations, that you'll ever convince me in the slightest, that a rod with a 200 ohm Ra sitting on it, is any sort of a TT system. What it is, is a bloody joke!!
Encouraging these younger sparks and untrained so-called DI's, to not even bother installing a decent TT system and just bung an RCD in, isn't the message we should be portraying either!!
Perhaps that's because you have been using these short thin twigs they now have the blatant cheek to call earth rods!! lol!! The Fens in Norfolk would easily give you TN values, if you know what your doing!! lol!!
