K
Is that right what im thinking, if the link is in between 2 and 3, that will allow me to switch 240volts on contact 1 yea?If the link isn't put between 2 and 3 the switching contacts 1 & 2 are electrically separate from the mains voltage running the clock (3 & 4). There will be no voltage supplied from the timer to either 1 or 2, which is why as I said you could switch a 12v supply connect to 1 & 2 without it getting blasted with 240v, as it would if the link was there.
What functionality are you trying to achieve?Basically what I've got is this for the scenario, and it's a manual override switch and and photocell and the timer you see there, and basically we have a supply from the mcb to connection 3 and that other brown there goes to the over switch and and two browns leave the overide switch and come back to 1 and two there, the slightly darker brown is the return switch wire from the photocell and the black and grey cores go to two separate contactors, is this setup correct?
No the two browns are the supply into timeclock from the left and it leaves and goes to a key switch which is a double pole switch and the two browns come back and go into 1 and 2 ??? That means it won't work with 240 volts output unless the link is there which isn't, is that correct what im thinking??It looks like the link is present: in the picture you have two browns going into terminal 3, with the right one looking as if it goes off to the switch. Is it an intermediate switch? I see it has four terminals.
So why are you working on this installation? Did it work before? What have you changed?That's the way this has been wired since ages
