Just to elaborate on my original post....
I tried all manner of wiggling, tilting and easing...but all to no avail. The pipework was so tightly pressed against the plugtop that you couldn't get a piece of paper between them.
In the end, I hack-sawed through the plug, removed it in pieces, and fitted a new surface-mount socket a few inches higher.
So you couldn't find your lump hammer & bolster that day then?? :)
still, if it's a -----up between having your ear drums abused or paying 30 quid for a bottle of inhibitor, i know which one i'd go for.
"Hello shagbite",
I am NOT trying to state that what I described is definitely the way to unplug from a Socket outlet in this kind of position - BUT I have yet to read any Valid criticism of what I described as a first TRY.
Without wanting to annoy any Members I am guessing that Guitarist looked at something similar to what I described before having to Cut the Plugs and remove them in pieces - there was obviously NOT as much `room` between the Plugs and the Pipes as it looked in the Photo.
Draining down a Heating System - Disconnecting the Boiler Pipework - Removing the Plugs - Refilling the Heating System adding Corrosion Inhibitor [+ £30.00] and then running the Heating for Hours / Venting the Radiators and having to then revisit the location in a couple of Days - IF the Heating has been able to be On for a few periods [obviously NOT in Summer] to Re-Vent the Radiators is MUCH more time consuming and Expensive than what I previously described that I would TRY first.
It is NOT just the £30.00 for the Inhibitor to take into consideration.
Regards,
Chris
I wouldn't even touch it, get the guy back charge the customer for lost time or a call out and suggest they counter charge the plumbing contractor.
"Hello pennywise",
I was writing from the imaginary position of actually being involved on a Job where these Plugs had to be removed.
Ideally of course an Electrician would be engaged IF I did not want to Drain down the Heating System - but as You know this is not always possible at short notice.
Obviously if I were just visiting or carrying out other Works My involvement in something like this would have to authorised and be paid for.
But IF an Electrician was not available I would still try what I originally described first.
For Safety I would isolate ALL Electrical Power to the premises rather than relying on isolating a Ring or Radial Circuit - and also check that the Boiler / Heating Controls were not energised in order to ensure that there was no power to these Socket outlets / Plugs.
Although obviously turning off the Main Isolating Switch on the Consumer Unit SHOULD isolate all Electrical Power to the premises.
Regards,
Chris
A plumber with a freezing kit should take no more than an hour to remove the pipes and alter the pipe work. :).
"Hello again pennywise",
When I have mentioned several times what I would TRY regarding removing these Plugs this was NOT to try and state that I know more than an Electrician about this particular task - But now You are trying to put it across that You know better than Me - a Heating Engineer - How to go about disconnecting the Boiler Pipework etc.
Where is there room to Freeze the Flow and Return Pipes at the Boiler ?
Please don`t write at lower level as We don`t know how the Pipework is configured lower down.
I know that You have never seen a `Plumber` Freezing Pipework adjacent to a Central Heating Boiler for this kind of purpose.
IF I ever ARGUED a point about Electrical Work on here with Electricians I would end up looking very `ignorant` about Electrical Installations.
Developing this into an `Argument` with Me - a Heating Engineer - is NOT likely to result in You looking `knowledgeable` about Central Heating Systems / Boilers - let Me assure You of that.
Let alone trying to tell Me about a `Plumber` Freezing the Boiler Pipework - `disconnecting it`- removing the Plugs - reconnecting the Pipework !
IF You want to `reprimand Me` about what I wrote - Please give Me some constructive `criticism` on what I described that I would TRY in my previous message.
I am fully aware of ensuring that there is no Electrical Power to the Socket outlets before attempting ANY method of removing these Plugs - which is why I wrote that I would turn off ALL Power at the Consumer Unit - just to be completely Safe - even then I would check the Boiler / Heating System Controls were NOT receiving Power.
Regards,
Chris
I'm not trying to have an argument with you about your technique in removing plugs, if my comments where originally aimed at you, I think I would have quoted you directly in the first place. I still would do as my first post :)
"Hello shagbite",
Regards,
Chris
chris, relax man. i don't think i said anything about your socket idea; i was just offering a solution that hadn't been mentioned yet.
what you describe above does sound a lot more involved than having a go at the socket, but like i said, i thought we were just throwing out options on how to get it sorted. i wasn't trying to trump your suggestion.
but i do think 30 nicker for inhibitor is dear (unless you're getting a gallon). the last bottle i bought cost £7.99.
Hi Chris, again.
Take it easy, mate, not like you. Only opinions flying about.
My opinon....send for Spud, without all the trimmings! lol!
Norfolk
Heating Engineer set me a challenge
Guitarist,
SPARTYKUS,
