S
Selena Francis
OK guys, I will give you as much info as poss so that you can offer advice:
I brought a second hand sauna, re-assembled it at home and wired the heater into 13a just to test it worked, which it did.
Ran a 6mm cable into a seperate RCD in our consumer unit - the heater kept tripping the GFI as soon as the unit was turned on. Upon the advice of an electrician we scrapped the heater and brought a new one.
Wired the new heater in (still 6kw) - same problem, the seller said this is an inherent problem with Sauna heaters and to replace the breaker with a 40a non GFI type, which we did.
A brief "Hallelujah" moment as everything seems fine, but sadly whenever the sauna starts to get warm, the main house RCD now trips.
Is this actually an inherrant fault with Sauna heaters? i did not expect a brand new heater to present the same fault, thus logic (of an electrical dumb----) dictates that maybe the fault present is in the wiring / earth itself. However this has been checked by an electrician and they say everything seems ok.
Hope you can all understand why i am baffled, annoyed and frustrated! lol
Any help or advice would be VERY much appreciated - i didn't buy the sauna to loo at it! ha ha :mickey:
Sounds like your sauna has an earth fault on it, it's not fit for use.
I'd be taking it back to the seller and getting a refund!!!
needs a thorough testing. maybe the new element is breaking down when it gets warm. maybe you have some earth leakage on the installation and the sauna is just adding enough to cause tripping. a spark with thorough knowledge of fault finding is required. if you post your location, one of us may be close to you.
well this is the second heater, the first was old, so i didn't mind replacing it but it seems off for a brand new replacement to arrive and present the same problems?
any ideas?
for reference there is a junction box on the side of the sauna - heater wires into that and then the 6mm wire comes from that too the consumer unit.
Obviously i will send the unit back for a refund if you guys are sure its the unit?
- - - Updated - - -
I am in Pembroke, West Wales - i don't fancy my chances of anyone being close but will live (post) in hope :D lol
ah yes, i should have noted that the sauna is located inside, not outside.
I am having trouble finding a specialist in yokalville (thats stupid for West Wales):(
Hi Selena , what make of heater and controller have you got ? Also you mention it now knocks the main RCD out when it warms up , do you know at what temperature this happens ? And at the risk of getting a good ribbing from the others ! What do mean by GFI ?
6KW Sauna tripping main breaker in house! - HELP?
Selena Francis,
Silly Sausage,
