Currently reading:
I should know better
Discuss I should know better in the UK Electrical Forum area at ElectriciansForums.net
Z
Zebra Stripe
Had a phone call today from a women asking if I could provide a certificate for some work her hubby had done. Ok I know what your thinking and I agree the answer would be “no chance” if it was major electrical works.
However, this would be for a change of light fitting and a kitchen fan……..all on existing circuits so MWC should have been issued.
Why does she need a cert?? Cos she’s exchanging houses either council or housing association and, she’s been asked for a certificate for the works that have been done.
Ok, so my thinking would be:
EIC?….no chance
MWC?.....well if I could test circuit(s) and look at connections…hmmm.. maybe, but still don’t feel right.
PIR whole install with EICR?? Maybe a bit over the top?? Just these 2No circuits with lots of LIMs?
Probably won’t ring her back as I’m not desperate for work, but I’m a sucker for a female in distress and some easy money.
Any views?
MWC. Go for it mate...
Still not sure..MWC with some testing & inspection although not strictly correct and a bit late would be financialy benefial to both parties...and being council/housing asociation they've probably been PIRed on a regular basis......although that probably consisted of a Ze, PFC and RCD test in my experience if your lucky....
tell em its a condition report their gettin..
council or whoever it is will be happy with that
Agreed MJD and strictly your right, but if you were to replace the fan and light, a MWC would suffice. So if I checked connections to the existing light & fan and tested and inspected there's not much in it.....perhaps Im trying to convince myself
The EICR only has to be for the fan and light, it could be filled in pretty quickly, if you issue a MWC then you take full responsibility for the work, an EICR your only saying it looks fine to you but you take no responsibility, your Call.
Full re-wire required here unfortunately as the installation is highly dangerous and could self-combust at any moment setting fire to the whole neighborhood, thus setting off a chain of events that could lead to the downfall of mankind and the rise of an army of mutant plumber ladyboys.
Damn, I'd made my mind up..now Im not too sure......mutant ladyboy plumbers sound easy to kill though
Reply to I should know better in the UK Electrical Forum area at ElectriciansForums.net
