- Reaction score
- 26
My sister has just had a shed erected in the garden and I'm going to install the mini consumer unit and run two circuits. One power for sockets and one for lighting.
I'll do all the dead testing of the circuits and then i'll be getting my college lecturer mate, who is a member of a competent persons scheme to (check my work) and then connect the supply before carrying out the live tests together.
The supply cable had already been run by the guy who built the house ( new build) but I'm curious how it's all going come together.
So the dedicated circuit for the outbuilding appears to be shared with the Solar PV circuit.
Starting from the distribution board..... 20Amp MCB ---> 6mm2 FTE runs through house to external weatherproof enclosure. Inside enclosure on outer wall, there is a connector block which connects 6mm2 SWA to a Solar PV array of just 4 panels. I'm guessing this is approx. 1kW. The panels have integrated inverters so it's 230Vac at the connector block. Also in the enclosure is the start of the 6mm2 SWA for the outbuilding supply, coiled up.
I've not discussed this with my electrician friend yet but was just throwing it out there for discussion.
![IMG_0351.jpg IMG_0351.jpg](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/27/27674-1f2b6d30c5662c8b6b8ee9afebd212c0.jpg)
![IMG_0350.jpg IMG_0350.jpg](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/27/27673-64daeee0afedb9de96d14cb577a8efc7.jpg)
