mainline
Patron
Nov 30, 2021
3,332
3,247,381
Cornwall
Business Name
Mainline services
What's the favourite tool for cable pulling and why.
I haven't used rods for a very long time, as I find these will go where rods won't.
Not got one of those in my toolbox....
Either 4mm rods, or a bit of mini trunking lid...
Stopped using fence wire a long time ago when the hooked end caught the only live cable above a suspended ceiling.
Tug, BANG!
Reactions: mainline and DPG
Depends on what size of cable.
I don't really know if rods would pull 16 mm Swa or T&E reliably without risking breaking a joint.
I use super rod kit , works well and if I need to pull some really heavy cables thrn I use them tu piYll
Used a Jack Russel once. Got him to run the full length of a loft conversion, behind the two foot high vertical walls, drawing a rope behind him.
i did once use an 8 year old boy.
(My grandson) was helping me fit a heater and trying to fit all 6ft of me in a small space to pass a cable through a hole was just not possible.
He did a great job, only took him 30 seconds to achieve something 10 minutes of my trying failed to achieve.
I not tried super rods but have a set of cheapo ones, very rare that i will use them.
I find that you can manipulate the steel to get in some places a rod won’t and everywhere a rod will plus they are cheap and lasts for years.
One tip is to cut off and make the loop smaller so that 1mm fits it snuggly never a need for any tape and very quick.
Great for downlights.
I'd say it's a combination of what's suitable and ... drumroll ... what you actually have with you.
I've heard of using a cat under floorboards - my experience is you struggle to keep them out anyway !
I dont like steel draw wires, reminds me too much of the old steel snakes we used to use for drawing wires into conduit, horrible things.
I just wish nylon snakes and super rods had been about in the 70s and 80s when I did a lot of house bashing.
Have you ever used the amtec type one ? It’s not round it’s flat and quite rigid and pushes on quite well.
Mine looks exactly like the one you posted a picture of but it doesn't say amtec on it. Bought it years ago but didn't like it.
Reactions: mainline
For conduit I like my nylon draw tape.
Gosh they aint cheap these days
Did you then send him up the chimney? :)
A fish tape is the favourite tool for cable pulling because it’s flexible, durable, and makes it easy to guide wires through conduits and tight spaces with minimal effort.
mainline
Patron
Cornwall
Business Name
Mainline services
What's the most useful tool for cable drawing
Hobby
Electrician Talk
Thread Tags
Tags Tags
cable
mainline,
hassan izhar,
