hi all,
Got a 2 gang switch in my utility one for frourecents and one for a outside light.
Thing is I want a pir switch just to do the utility lights and switch the outside separately without chopping in another switch , found this and was wondering if it was any good
GI2DPC - 2 Gang Green-i Double Dimmer with PIR Movement Sensor, No Neutral Dimmer with Presence Detection - https://www.sparksdirect.co.uk/2-gang-green-i-double-dimmer-with-pir-movement-sensor-no-neutral-dimmer-with-presence-detection
Don't want both coming on on the pir but not sure I can do it, mind you now thinking about it imsoppose it doesn't matter if the outside light comes on as well ,mmmm
Cheers
Grand
It states Incompatible with linear flourecent tubes but then goes on to say max 150w for flourecent so can't see any reason why not.
No it's a dimmer how deep is the K.O back box as Danlers make one for europlates NEED 35mm box and neutral or one that goes on the end of fitting.
Midlands
Electrical Engineer (Qualified)
2 Gang pir switch
grandfortune,
Richard Burns,
