E
Elidor
Got a 2 way switch in a bedroom. 1 switch operates the main bedroom light and the other operates a selv transformer with a set of downlights. Bothe sets of lights are in the room. The 2 way switch is cabled with 1 x 3 wire (Blue, Yellow and Red) this single switch wire is cabled out to a junction box in the attic where the red cable is connected to the Line and used as live for both switches. Is this common / acceptable practice or do I need to run a seperate switch wire for each?
the lazy mans switch!!!
not uncommon to find..!
ideal situation would be to have independent power supply to both switches...
i dont seeany problems with that. its very common to utilise one feed to a switch, and then seperate switched lives to the fittings.
Well I was thinking if both lights are on at the same time then both circuits are being powered form the same core in the cable, kinda doubled its load. I dont know for sure what size it is ill have to check again when i go back.
And the cable coming out of the CU is carrying the load of all the lights on the circuit
if your switchline is the same size as the cable feeding the whole circuit, then there is no problem. even if it is say a 1mm2, then i doubt your lights will overload this.
obviously for peice of mind, you should carry out some cable calcs if your unsure.
