Discuss 2 way switch using 3 wire? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
E
Elidor
Got a 2 way switch in a bedroom. 1 switch operates the main bedroom light and the other operates a selv transformer with a set of downlights. Bothe sets of lights are in the room. The 2 way switch is cabled with 1 x 3 wire (Blue, Yellow and Red) this single switch wire is cabled out to a junction box in the attic where the red cable is connected to the Line and used as live for both switches. Is this common / acceptable practice or do I need to run a seperate switch wire for each?
Well I was thinking if both lights are on at the same time then both circuits are being powered form the same core in the cable, kinda doubled its load. I dont know for sure what size it is ill have to check again when i go back.
if your switchline is the same size as the cable feeding the whole circuit, then there is no problem. even if it is say a 1mm2, then i doubt your lights will overload this.
obviously for peice of mind, you should carry out some cable calcs if your unsure.
Reply to 2 way switch using 3 wire? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
