J
john1975
Hi
We recently had a electrical testing firm in to do some PAT testing in the offices we manage over two Saturdays. The first week there was 5 guys and they done about 2 - 2.5k in a day roughly 6 or 7 hours. The following saturday we had 6 of them in and they done about a further 3k. When I asked them how they are able to do so many in a day one of the guys said it because they use pre printed lables and use the europa plus which does all the tests automatically. Alos they work in teams of two one will label and visually check everythign while the other tests everything. Is this possibel as most people say they would struggle to do 200 a day??
Tosh. The ONLY way you could do 500 items in a day would be to have them all laid out in a line for you to test.
1000 items between 2 people, even with the labels pre-printed, sounds like a tall order. From what I've heard the Europa gets a bit hot and cuts out if you use it at the rate they reckon they've had it going at.
You can't really do the tests at the same time as someone is taking the plug apart to inspect it either.
One way to check...If they are using the Europa then they will have the software that goes with it - ask them for the overall print out of the appliances, if all of them are logged and on the print out then they would have tested them all....
I've never done PAT testing but this sounds like good advice to me.
My all time record was 300 in a long day, with prepared labels, in hotel rooms.
One room to the next, items exactly the same, with a 'smidge' of testing! :-)
Anything >300 is definitely just stickering
well , well , well........
the almighty instr. tech. reveals hes sunk as low as pat testing in his illustrious career.
and you sure youre qualified to hold that broom handle ?
As a Yorkshire man, I've already sold my soul living in Manchester (somewhere near Lancashire apparently), so a bit of PAT brings in a bit of cash....I've got no shame! :-)
suppose it makes a welcome change from the roller-coaster world of tapping gauges with a biro.
carry on.
5 minute an item 20 an hour 160 in 8 hours but no breaks even for a Pee plus tester get red hot mmmmmmmmmmmm I dont think
ok you got 2 testers and who is logging Make,Model,Class,Fuse size , Location
3000 items in a day??
Electrical Testing & PAT Testing Forum
Thread Tags
Tags Tags
items
john1975,
Hiddo,
