Search the forum,
Discuss abour ryelield board.. in the UK Electrical Forum area at ElectriciansForums.net
hi there.. bit advice please..im installing 24 way ryefield board..im bit confused for neutral bar ..neutral bar its linked to body of ryefield board ..there its warning label who say '' if its SNE earthing system please remove link..on the meter room main incoming supply its PME..im not sure if i have to remove that link or i have to live as it is..
SNE is not PME. I'm not sure whether to answer because generally if your installing a ryefield board you should know the answer to this. Do you know what SNE is? Or why the link would need removed?
SNE = separate neutral and earth..PME = TN-C-S = protective multiplay earthing..
on my experiencies i never see SNE system anywhere..in my opinion SNE its very rare used system but im not sure..theorically neutral conductor its same as earth conductor..both of them come from the earth..
Reply to abour ryelield board.. in the UK Electrical Forum area at ElectriciansForums.net
