I've got an old floodlight outside my domestic property that I want to replace with a new Low-Energy unit. The new unit has no PIR, so just has a Live, Neutral & Earth connector inside the IP65-rated housing. The connector itself has push-buttons cable clamps a bit like cheap speakers have, so no chance of overtighening any screws!
The old floodlight was PIR-controlled, supplemented with a manual (override) switch from by the back door. A single cable (three-core plus earth) supplies the old unit. The red core is always live and feeds through the PIR, the yellow core is the switched live from the switch by the back door. The blue is the common neutral.
If I swap the old unit for the new, I'm going to have the red conductor left spare and I'm wondering how I should terminate it. I really don't want to have to pull the cable back in side the house and replace it with twin & earth as this will mean lifting the carpets and the floorboards to get at the junction box. Is there an acceptable way to make the spare live conductor save within the light fitting?
As you will guess, I'm not a registered Part-P 'Competent Person', but a capable DIYer. I understand that Part-P allows me to do this work without notifying building control because there is no external junction box involved.
Any advice appreciated - even "Get an Electrician in", if you can explain why. :)
Cheers
Tony
Re: Acceptable means of making a spare live conductor safe - inside external floodlig
just terminate the red in a block connector to make safe, but be aware that even though the new light is switched off, there will always be a live there unless the MCB/fuse feeding the circuit is isolated.
Can you not disconnect the permanent live supply (red core) at the switch??? just leaving the switched live an neutral connected???
As telectrix has said but lable the perm live as perm live so people working on the fitting know know
I think I have some chocolate block connectors somewhere. I'll use one of those and label as suggested by Nick.
Thinking about it i would probably use a wago push fit connector rather than a terminal block
I've tried to analyse the wiring in the JB and would guess that it looks like this:
If this is the case, I don't understand how Lenny's answer applies?
I would guess hifly's point about spare conductors being earthed at both ends is so that in the event of a fault at one end of the conductor, the other end doesn't become live.
if its connected to an earth terminal at both ends you don't have any floating wires in chock blocks that you or the following person have to investigate further as to whether its live or not, you also don't have to use any extra components or find room in the enclosure for it. Also in the event of a fault of nail through cable one end can become seperated frrom the other and the unconnected end could be live without fuse blowing.
Why should spare cores be connected as an earth at both ends????
It's common practice for an unused core of a multi core cable to be connected to earth to eliminate any induced voltage.
Sorry Lenny for dropping in like This . Am very Sorry about this “ Warning
PS. I don’t now where to drop this One ????
Postal Scam:Can you circulate this around especially as Xmas is fast approaching - it h=as been confirmed by Royal Mail. The Trading Standards Office are making pe=ople aware of the following scam:A card is posted through your door from a company called PDS (Parcel Delive=ry Service) suggesting that they were unable to deliver a parcel and that y=ou need to contact them on 0906 6611911 (a Premium rate number).DO NOT call this number, as this is a mail scam originating from Belize.If you call the number and you start to hear a recorded message you will al=ready have been billed =A3315 for the phone call.If you do receive a card with these details, then please contact Royal Mail= Fraud on 020 7239 6655.For more information, see the Crime Stoppers website:http://www.crimestoppers-uk.org/crime-prevention/helping-prevent-crime/scam=s/postal-delivery-scam
The Good Lady works for the Government . I’ll leave at that . Amber Sorry about this . Thank you Lenny .
I seem to remember reading about unused conductors being earthed in one of the niceic snags and solutions books
What I assume the OP has is a L&N supply to a switch by the back door and then a 3C & CPC up to the outside light. The red is connected into the common of the switch with the perm live supply of the T&E, the yellow will be the switch wire in L1 with black & blue in a connector.
Hence my suggestion of disconnecting the red core.
all spare cores should be connected to earth, disconnect at the switch, dont have a spare perm live at the light.
Just playing the devil advocate here, not sure how the NICEIC interprets that connecting loose cable to earth comes under regulation 131.2.1.
Providing as in the NICEIC example and those un terminated cables are in an enclosure, and therefore the enclosure is afording basic protection, why can't the cables be
1) Terminated in a connector block or wago block.
2) Doubled over at the ends and then taped over with insulation tape.
I have yet seen at a DB an isolated circuit either permanent or temporary with all 3 conductors connected into the earting bar. Just an argument
I thought similar, hence my 'interpretation' remark. I'd sooner refer to induced voltages R.E. Sintra's comment before thinking about reg 131.2.1
Sometimes I wonder if the NICEIC have missed their calling, rather than being an electrical organisation, perhaps a job in the UN council as intepreters would be more their bag
Acceptable means of making a spare live conductor safe - inside external floodlight
Australia
tlangdon12,
malcolmsanford,
