Discuss Advice needed: Economy 7 boiler switch in the UK Electrical Forum area at ElectriciansForums.net
J
Jason63
I need advice in regards to connections to an electric boiler with two immersion heaters. At present, there is an on peak switch connected to one immersion and off peak switch connected to the second immersion. The first immersion is not working anymore. I want to connect the working immersion heater such that it works off peak and on peak using one switch. Should I use a double pole changeover switch?
The bottom immersion should be off peak and designed to heat the whole tank, and the top immersion should be used on peak and only really should be used as a top up ( using just the top element might not heat the whole cylinder). My advise would be to just change the faulty immersion or get a dual immersion heater that will replace just the top immersion, these are normally longer hence will heat whole cylinder properly.
Thanks. It's the top (smaller) peak immersion that is not working. Hence I wanted to feed the bottom (bigger) heater with a choice to run it with both peak and off peak lines. Do you see any downside of using a changeover switch?
All you need is a Horstman E7 controller , this operates the single element and has a timer all built in and also has a switch / countdown timer use as a boost should all the water be used, there is also an E7BX unit that can have both off peak and on peak supplies all connected and supplies either a single element or two elements , , this incorporates a changeover switch all built in and is made specifically for this use
Agreed. But surely just changing the element is much simpler and cheaper.
Re Reading this post again , it sounds as if its the on peak thats working and this will only be heating a part of the tank , so I agree its a case of element replacement other wise amount of hot water is restricted ...
Tbh it looks like you have given this much more thought than I have. :)
I'm not an overly complicated person I just go for simple is best :)
Reply to Advice needed: Economy 7 boiler switch in the UK Electrical Forum area at ElectriciansForums.net
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Until last week I had a dual tariff electricity supply with a cheaper overnight tariff. This was good for the storage heating, but now the storage...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
