I think it has all been said above but:
Your part of the installation needs to be installed in compliance with the current regulations.
Because you are making an alteration to the installation the earthing and bonding need to be adequate for the protective measures you are using.
The parts of the installation that you are employing for your alteration must be suitable for the changes you are making.
Because you are adding a socket and intending to bury the cable (without an earthed sheath and not protected against penetration), presumably less than 50mm deep, in a domestic property then the cable and the socket need to be protected by a 30mA RCD that operates in the required times.
The circuit you are extending needs to be able to carry the increased load anticipated, must meet the required disconnection times for ads, the supply needs to be capable of meeting the new load requirements.
