L
lukeysim
I am currently at college studying 2330 level 2, and im just wondering what the regulations are to carrying out basic electrical work at home.
According to the wiring regulations it would depend on your level of competence (ordinary person, skilled, instructed or competent) - This will be non statutory.
According to the Building Regulations it will depend on the work specifically and how it falls within the scope of Part P - This will be statutory.
What do you consider to be "basic" work?
yes - you can do any work you like- including full rewires - however it may require to be notified to your local building control
What he said! ^^^^^
But take a look at this, it's a list of what you can do without LABC notification:
The Building Regulations 2010
You can do anything you like it is your own home, if you wish to comply with statute law and industry guidance then that could be another matter.
As far as I understand it, you can do anything you like in your own home, :cowboy: except where it might affect others around you :drummer:(Gas etc). However, your insurance company might take a different view... and then there is building control :detective:
It is generally correct. You can do as you wish in your own home, i'd advise checking with your insurance company though regarding it.
I had to wire in a seperate system with an earth spike to bypass the PME system someone felt the need to install in my house before i got it.
Yes very interesting.
That would seem to contradict what is contained in the Approved document:
[TD="bgcolor: transparent"] d. In large bathrooms, the location containing a bath or shower is defined by the walls of the bathroom.
[/TD]
If it was a DNO supplied PME, it sounds like they knew what they was doing then!!!
Basic answer to the OPs question is YES you can do DIY on your own house solong as you read and comply with part "P" in respect to LABC and notification This is a bit of a flaw in part "P" as basicaly it says competant people but defines it in such away that ANYONE can do the work only scheme members can sign off their own work so guys like me who arent part"P"P as we do mainly company commercial work cant sign off on the form BUT we probably look firther into things and check more than some D.I.s and 5 week wonderboys
Iv always understood the term to be "A room containing a bath or shower" not nesecarrily a "Bathroom" as some large houses and "Architectural designed" piles of cack CAN have a bath/shower within a bedroom hence the ZONeS being set out around the bath and not the room
Lottery win n Ill be having house built with bath in bay window overlooking the countryside the house is getting built in Have even drawn sketches for it the bbq are tennis court indoor swimming pool with sliding glazed wall ffs she has even got a dressing room attached to every bed room AND a big shed down the garden entilted "Johns Rest rooom" my contribution to sketch is my 5 car garage n "pool room" with pole for the visiting ladies lol
