I am just about to go and look at a Job, please feel free to crash this thread, if only one DIYer reads the OP one old aged pensioner may not get fleeced, i will be back later for some more fun and laughs
Fair enough, but where are you going to stop with your free online training?! :-)
Switch all the lights on, switch the breakers off, disconnect the neutrals and then measure between them with your I.R tester @250v, lamps in fittings.
If you want a solid test, try R1+Rn. Like the R1+R2 test (where you bridge L and PE at the CU and go around with a continuity meter), but bridge L and N at the CU instead (disconnecting N from the N bar, so it's connected ONLY to it's own circuit's L). If you get open circuit at a light fitting (with switch closed) then the N has gone astray.
Another way to do this - Clamp ammeter to neutral of one lighting circuit (dead) while other lighting circuit is live with ALL lights on - if you show a current on the 'dead' neutral then switch lights off in turn to id (normally landing)
I usually say a £50 pre work survey is done first to identify any issues, then this comes off the bill at the end. I normally do this during the week before the board change. its 'unlikely' that anything will break or cause problems in-between doing that and changing it, admittedly I do global IR's just as a good measure just before I rip it off the wall.
Its not just a case of finding if you can fit a new board though is it , What are you reconnecting , I am inclined to do a good visual even before doing the testing , near enough an EICR , Charge for half a days labour say £90 + VAT (subsidised), and offer this as a deposit of the new Board and any remedial works , If you do find faults I always include these in the quotation and explain this to the customer and and always stipulate on the quotation that any additional faults not found is subject to extra cost ..
Its not just a case of finding if you can fit a new board though is it , What are you reconnecting...QUOTE]
Where do you draw the line between only being responsible for the board change and then opening a can of worms on the installation when doing a visual knowing there's some rough work but will still work when connected?
I always make it clear what needs to be done to bring the installation up to standard , If the customer doesn't want the work doing, I advise them that I personally would not carry out a board change without it , If its a case of rough work but still compliant , I again would advise them and also explain that this would be noted on the Installation Cert , as far as I go I do not use the comments box on the certificate to explain non compliances after I have changed a board for them ,,,
I don't discount the rate for testing the existing installation, nor do I offer to knock that amount off of the cost of the CU change. That work and the costs involved are part of the CU change as far as I'm concerned, not 'nice to have' additions.
I'll happily compete with anyone on quality of work and materials, but I have no intention of competing with anyone to see how cheaply the job can be done. The costs involved in running my business (as opposed to a not for profit organisation or charity) are what they are. All this discounting this and knocking off that is a race to the bottom.
Fair Point ,, All I would say is I am not the cheapest by far , when you look at the total price for the work , I just find the procedure you apply makes you look more professional and customer always knows where they stand, if you make it clear.
If your way works for you then thats o/k , as regards price structure ..
There are many ways to earn a living/run a business. I'm not criticising anyone for the way they operate, just pointing out that once you start on the discount route it can be a slippery slope.
imago and ray, you two guys are sparks discussing what we would assume to be the norm here, don't forget the guys who change these dbs and then get all flustered when problems occur are not electricians, therefore your conversation is irrelevent in this thread, your over qualified here lol
