M
MDJ
Disconnect the wiring from the existing "fuse box" go around the house and unplug everything, and I mean everything from the socket outlets, remove all light bulbs from lights and ensure all switches are on. Then remove a IR tester from your tool kit and send 500 volts down all cables which have been disconnected from the "fuse box" send the voltage between cores of the individual cables. For example if you have a twin and earth which was the supply to the lighting circuit and it has a red, black and a bare core then put one prong on the red and the other on the bare core and send 500 volts down it, then do the same between the black core and the bare core, then between the red and black cores. This will let you know if there are any problems which may inhibit the new RCDs in the new Distribution board you have bought from holding in. You would carry out this basic test on all cables, which includes cooker and sockets as well as immersion heater and so on and so on, ensuring nothing is connected to any cables anywhere and all cables as mentioned are completely disconnected from the "fuse box".
Once this basic task has been carried out you will know whether an issue or two may be evident, the new distribution board is still in the new shiny box at this time by the side of your tools and has not even been removed from the new shiny box it is in. If you have found a problem you can then tell the customer before anything else happens what the issue is and how it need to be rectified etc. If there are costs involved you can inform the customer before changing the fuse box" and they can then decide whether to allow you to continue or to tell you to just leave things as they were before you entered the premises.
This way at worst you would have lost an hour or two on site but no more and it is very likely 9 times out of ten should there be an issue the customer will give you permission to carry on and you would have gained more justified work legally which will get you credit and respect and indeed future work, thats the basics, once this is out of the way providing you get permission to continue if problems are found you can then continue to replace the "fuse box" and test all circuits on completion properly and to the book which you paid up to 6k for on the course you learned from. The tests I mentioned are the very minimal basics just to try to see if an issue is evident on existing circuitry, there is a lot more which could be said so over to the others here to chip in and take this basic working method further. Please understand it is essential that a proper set of test instruments are used which have been confirmed as accurate, the scheme you have paid into will be able to advise you about test kits.
