Discuss Best value fire rated downlights in the Electrical Tools and Products area at ElectriciansForums.net
Hi everyone,
Been fitting the cosmos eco from Screwfix, but more time-consuming as yiu can't loop in / out. What's you're best push in easy fit alternative...under 72 quid?
I use the lap cosmos. IP65, fire rated and dimmable. I've never had one fail. I keep a couple in the shed in case one does fail and screwfix don't sell them anymore.
They have 2 push fit connections for each of the line, neutral, earth and a spare, so I'm not too sure what you mean by 'loop in', as they are designed to take 2 cables, one in, one out.
Here's a picture of the inside
You likely won't beat the price of those for a full integrated unit without going cheap ebay, but that's likely for a reason (though I've fitted plenty of LAP ones with not many comebacks).
Last job I did where I was definitely NOT going back, I used the Aurora EN-DLM981X ones - need to buy the lamp separately, but means tenants or handyman can change them.
Fitting about ÂŁ4, Bezel ÂŁ2.68 for an IP65 or ÂŁ1.26 for a non IP rated one - then a couple of quid for the lamp and you're sorted.
I think they do a version with push fit terminals and one without.
I'm going with the Luceco F-type for my current job, they seem well made and have a decent loop in/out terminal - 10.78 a pop at Toolstation and changeable bezels available so ideal for decorating, etc.
Reply to Best value fire rated downlights in the Electrical Tools and Products area at ElectriciansForums.net
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi all, about to do a condition report on a grade 2 listed 4 bedroom property, the owner is moving and wants to rent it out. The consumer unit is...
7K
Hi all We've had some works done in our kitchen which has involved fitting a new cooker circuit, installing some downlights to replace ceiling...
