A
Alan42
Hi all, I've just spent most of my Sunday trying to answer this question: what bonding is required for a gas central heating system where some pipes are under the suspended timber floor? I have to consider this in connection with a consumer unit change, the gas and water main bonding is in 10mm which was (presumably) OK'd by the sparky who wired the new kitchen a few months ago and I now have to renew the board with a nice big Crabtree one with 2 - 30mA RCDs. The system had a 4-way and a seperate 1-way rewireable fuse board, both fed by a 30mA RCD. I see it like this: the boiler has a cpc in the flex that connects it. The pipes under the floor are clipped to timber joists where visible. 411.3.1.2 requires main protective bonding of central heating pipes where they are extraneous conductive parts, ie liable to introduce earth potential into the building, so if the floor were concrete I reckon all buried pipes would need bonding with a 10mm cpc. Now, the pipes in this house are nicely insulated with nylon clips and timber joists as far as I can see, but just in case there is a possibility of contact with the sub-floor I propose to connect the 2 pipes that come out of the floor with clamps to a spare loop of the existing main bonding cable that runs past them. There is plenty of slack in the cable, so I can do it without cutting. Am I right? Many thanks in anticipation.
