M
monkee
BT points can any one guide me on the best results do your have you main router connected to your master point of the home ie the one BT tell you to split into two for testing or can it go any were , should you connect 2, 3 , 4 & 5 or can you get away with 2 ,5 what dose the others do, with the old days yes but do will still need them today! with the number of points should you do one in four for a master if you go in and out daisy chain many thanks
daisy chain is preferred. just connect 2 & 5. router might work a bit faster if connected to master, but usually makes little difference.
That's my thoughts too, just got a customer moaning about internet speed and that I had fitted it to the wrong one it only makes a difference when you have very little to begin with cheers any one else
Yeah just use 2 and 5 and shouldn't makes any difference if u use the master or secondary point for the router. Also think the maximum number of secondary point is 4.
be my guest. the moulton marauder strikes again. btw. was in moulton t'other night. old guy i'd done work for 12 months ago had total power loss. went out 6.30pm. no power. lost neutral. had to call in sp energy, digging up the road to find corroded joint. estate only been built 20 years.
are they saying their broad band is slower now. what can happen is while you were working on it the system if not turned off keeps trying to find the signal and drops its speed again and again and again. If you have your 50v at each point and phones are fine that is prob the cause. Only use the 2 wire system do not connect on anything other than 2 and 5 unless old phones etc are being used (not with side router though)
the mighty tel sees all, reads all, learns nowt.
edit: the nickname "the mighty tel" came from a poker school i used to be with. playing texas hold 'em. there were 2 full houses, both with court cards, and i was holding 4 5s. was a mighty earner for tel.
Can't say encountered that one but was working away last week, next time in area pop in for a brew I'll treat you
The number of sockets on a phone line is unlimited (within reason). There is a limit on the number of phones and other devices plugged in. Normally this is given by adding up the REN (ringer equivalence number) of the phones. This should not exceed 4, otherwise there is insufficient ringing current for them to work properly. A standard old style BT phone had a REN of 1.
Daft question maybe, but I'll ask it!
Why is 3 connected in a lot of houses?
If you find 3 connected it can improve broadband speed quite noticeably if you disconnect them as it reduces interference on the phone line. If you come across an installation with an I-Plate or Interstitial plate fitted these were installed to disconnect the old bell circuit on terminal 3 in the early days of ADSL broadband
Don't know if they are still available but a number of years ago there was a REN booster available which allowed up to 11 REN on a line
BT sockets
monkee,
monkee,
