Discuss Certificate for replacing a main 200amp isolator in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys just replaced a 200 amp main isolator in a factory along with a replacement 3 phase board should you do an installation cert or a minor works as it's like for like
Before we start anything like this we like to get as much information eg existing certificates, circuit charts etc and turn off each circuit to prove what it feeds so when reinstalled we know what it does for retesting and is safe to bring back into service.
Got the old certs for the board mainly concerned about the main isolator I'm tempted to issue a minor works for it but would any one issue different
As Westward10 (who beat me to it while I made a cup of tea) posted I would do an EIC this is more than minor works you have the circuits in the distribution board to consider. You are required to put this information on the certificate anyway.
You need an Electrical installation certificate for the new board and all finals circuits within, plus the new isolator.
All tests will be from an initial verification prospective and will include all tests performed in the sequence stated.
Apologies if I'm telling you how to suck eggs
Reply to Certificate for replacing a main 200amp isolator in the UK Electrical Forum area at ElectriciansForums.net
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
When working in a control panel. If I needed to replace a 3 phase contactor do I need to carry out a 10point check to prove dead on just the mains...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
